Who would win at the track?
What car is faster in the 1/4 mile? A stock 1995 Max gxe auto or a stock 1995 Max se auto? Or are they the same?
What about a 95 max gxe auto with frankencar intake vs a 95 max se auto with tranny cooler?
Re: Who would win at the track?
Re: Re: Who would win at the track?
Originally posted by pezking4
Depending on the options in each car, there could be just a slight weight difference if one of the cars has less options. The cars are going to be about even stock.
yep, what he said.
BTW, a tranny cooler does nothing for speed.
Are both the cars in perfect running condition? There are some little tricks you can do to give yourself a slight advantage. Remove weight from the trunk of the car (spare, jack, trunk floor board), remove the A/C belt, bump your timing up a few degrees, clean out your TB really well, etc.
Originally posted by 96BLUMAX
GXE because steelies are lighter and GXEs weigh less.
Originally posted by BriGuyMax
myth
myth
does anyone know if the Nissan part numbers are different?
Originally posted by JeffesonM
are you sure about this? my mom has a 95 GLE and I've got a 99 SE and mine definitely feels harsher. it could be that hers has 100,000 miles more than mine, but I believe she's had the suspension once.
SuDZ
Originally posted by JsL
How do we do that easily? I thought you need to change the ECM...
95 SEs have ALLOY 15in. rims which are the near the same weight or LIGHTER than the 15in steelies...
this is incorrect.. the gxe rims weigh about 14 lbs .. the SE rims are heavy
now if your talking about the GLE rims your correct
Bags is right. My '96 15" SE wheel weighs about 19lbs. Combined them with the Bridgestone RE950 tires, they weigh in at 44lbs. Pretty heavy for stock wheels and having the usually heavy Bridgestones don't help.
mkaresh
03-12-2018 06:48 PM
