one more question on brake pads install.
i just finish installing my new pads and rotors.. but when i installed the new pads there were no holes on the pad for the pins to stick into. so i left the pins out.. is this a problem.. i got the pads from jr nissan...
You may experience a little noise and reduced mileage from dragging. The way I drive, mileage is not a concern. The Proterfields I have didn't have the holes, so I drilled some.
I believe that the '98 & '99 have a different design to keep the pads off of the rotors. I have been told that you use the later 4th gen brake hardware kits on the earlier calipers, but I haven't tried it.
Re: one more question on brake pads install.
hope that answers some of your questions.
-john
Originally posted by StygianMax
Did you paint the hats yourself? If so, what prepping did you do? I have a couple rear rotors whose hats I want to paint.
Maybe they made a change in 97 so 95-96's are different.
03-12-2020 12:06 AM
bbsitum
09-11-2015 04:55 PM
jds22
09-04-2015 01:52 PM
