anyone else have #$%*ed up speedometer?
Old Nov 20, 2002 | 09:24 PM
andrew23's Avatar
My max has 143,000 miles and my speedometer is on the blitz. It's been doing it for a while but now it is getting worse and I can't stand it. Sometimes when I'm driving down the road, it just falls down to zero. If I knock (or beat) on it some, it jumps back up to normal. I replaced the speed sensor but didn't fix it. Also my cruise control is messed up. When I push the set button, the light only flashes if it comes on at all. I don't know if they could be related. I need to get this fixed before I mess up something else when I beat on the dash to get the speedometer working again. Thanks for the help. I think this site is really cool. I almost want to get another max when I trade just because of all of the cool info everyone posts.
Andrew
Old Nov 21, 2002 | 12:18 PM
phenryiv1's Avatar
Mod her. Ate her.
Re: anyone else have #$%*ed up speedometer?
Andrew
My first Jeep used to do that. Only when it was cold, though. I just chalked it up to good 'ole American know-how. I guess it spans the globe, though...
Old Nov 21, 2002 | 12:21 PM
Speebs's Avatar
I aim to misbehave.
Andrew
I have a working speedometer from a 95/96 that I can send you. I don't remember how many miles are on the odometer, but I can check for you this weekend if you want. Just send me an email or PM if you want mine. My tachometer started doing something similar a few months ago and replacing it fixed the problem (I guess the magnets that turn the needle were screwed up somehow).
Old Nov 21, 2002 | 12:24 PM
maxima4me's Avatar
I have the exact same problem. Not with the cruise, but with the speedo. My guess is that it's a loose wire somewhere in the dash. Why else would it suddenly work when you beat on the dash? I'm just not motivated enough to take the gague cluster out and look at all the connections.
Someone correct me if my assumption is warped.
Old Nov 21, 2002 | 12:49 PM
andrew23's Avatar
I guess I will just check to see if there is a loose connection in the back. If so, then I will check on getting another one or just deal with it until I get rid of my max. Thanks for the replies
Andrew
Old Jan 6, 2003 | 02:59 PM
thetobias's Avatar
same thing here.
Replaced the speed sensor a month ago and still no fix to the problem. Most of the time it works fine but more frequently now the speedometer will die after taking off from a stop and then pick up around 15-35 mph and work fine. Very occasionally it won't start working until after a couple miles...but usually after it jumps back up it stays working...until the next trip.
If i hit the trip-ometer reset button when its not working the speedometer will jump up and read an accurate speed but then will drop to zero when I let the button go. Also, I have the problem much less frequently when I let the car run for ~1 minute after start-up.
Old Apr 16, 2003 | 06:41 PM
Norel's Avatar
Andrew
I have the exact same problem, and if i smack the top of the Guage cluster, it jumps back to life too.. Im worried that my Speedo may be shot, or on its way out.. i got the TCU dig as a falty speed sensor, but from what it looks like getting that fixed wont do anything.. what should i do? or where should i take my Guage cluster to get fixed?
Old Apr 16, 2003 | 08:26 PM
tyrotrader's Avatar
Ditto! more frequently the speedo stays at 0 for few minutes then jumps to correct levely; I've no idea what causes it, I'll check back to see if anyone knows the mechanics of this proble.
Old Apr 17, 2003 | 04:58 AM
mrmaxima97's Avatar
I replaced the speed sensor but no good. I am hoping to get another guage cluster soon so I can swap it out.
For everyone that has the problem, have you noticed a loss in power from it?
Old Apr 17, 2003 | 06:17 AM
Kehops's Avatar
I'm in the very late stages of this problem. At first it would jump up and down but now it's just stuck at zero, even if I smack it....nothing. From time to time though when I'm cruising it'll jump back up for a second but that's about it.
Have you noticed it doesn't count the mileage when it hits 0??
Old Apr 17, 2003 | 07:49 AM
butchbr73's Avatar
Same thing here... speedo comes in and out. Most of the time it works, but just drops to zero, or sometimes gets stuck at some speed, or sometimes jumps to 85 and stays there! Mileage doesnt click when it happens. Speed control WILL work when the speedometer is not working on my car, which would lead me to believe its not the speed sensor.
I've tried banging on the dash, no help... Oddly enough, turn the car off, turn it back on, works again. Could it be some sort of short somewhere? Seems to happen all at one time, its been working for a few months straight now, but earlier this year, Jan/Feb, happened almost everytime I drove the car, would bounce in and out. Very wierd.
Brent
97 SE 5 sp. no mods.
Old Apr 17, 2003 | 08:19 AM
andrew23's Avatar
Re: Re: anyone else have #$%*ed up speedometer?
I just bought a new cluster from a junkyard, had it put in and have had no problems since. Hope it works for you guys too.
Andrew
Old Apr 17, 2003 | 08:47 AM
happyricefob's Avatar
V^___^V
i have 95 GXE and i have euro gauges installed with red-painted needles. after the installation my tachometer and speedometer does not indicates properly. my temperature gauge was over "H" the whole time.
anywayZ, i took out the gauge cluster, applied some double-sided 3M tapes at all corners around the gauge to make sure it is being pushed down all the way. then i took my nail-cutter, trimmed off the parts tat's stickin out in the center of the gauge needle to prevent the needle makin contact against the gauge face.
for the cruise control, it got jacked up after i tightened my throttle cable. i do suggest tighten the throttle cable but not too much, cuz if u have automagic it'll shift really fast and u'll have horrible control over ur gearing. in addition, the cruise control will not recongnize the new settin therefure the cruise will not apply.... at least not until the ECU relearns how to cruise.
so yea... tat's how i fixed it until recently my temp gauge got jacked up again, but i'm too lzy to take out the gauge cluster again... anywayZ i hope my lil tech info will help. if any additional information regarding fixing this problem or anythin i did wrong please reply.
Old Apr 17, 2003 | 09:37 AM
Speebs's Avatar
I aim to misbehave.
I still have this if anyone wants it
Old Apr 17, 2003 | 04:03 PM
Norel's Avatar
Re: Re: Re: anyone else have #$%*ed up speedometer?
you have mail
Old Jun 15, 2003 | 03:43 PM
tyrotrader's Avatar
bump
Old Jun 15, 2003 | 03:58 PM
ivelweyz
did you check whether it's a loose wire somewhere behind the gauge cluster...
Old Jun 15, 2003 | 04:44 PM
Slickismax's Avatar
Its the speedo itself. You have to replace it. Its a common problem on 95-96's.
Old Jun 15, 2003 | 09:49 PM
Norel's Avatar
yep i was throwing a speedo code in my tranny computer and i took it to banner here in on Long Island in NY, and the guys where saying that in a lot of jap cars, their are two speed sensors, on in the Tranny on in the cluster, he said the tranny speedo was fine as was the revolution sensor, and he suggested having the cluster looked at. next step is to get the cluster examined but im in no rush, not really doing it as much as it use to, knock on wood
Old Jun 24, 2003 | 08:34 PM
WaZ's Avatar
WaZ
Same problem.. Speeodo goes on and off. Got a new speed sensor put in.. no help. checked the wiring from the sensor to the cluster.. no problem. which means it has to be the cluster. Now the problem is, I got a used cluster from a junkyard and it has way more mileage than mine. Does anyone know if i can calibrate the mileage? I mean.. it has to be legal, i'm just trying to be match it to my current mileage. Any shops offering this kind of service?
Old Jun 24, 2003 | 10:06 PM
greg82's Avatar
I don't have a problem w/ the speedo so much as the tachometer, the needle doesn't rise and fall smoothly but in jerky movements Like in small increments or something. This happens maybe 2/3 of the time. Maybe the problems are related?
greg
Old Jun 25, 2003 | 09:54 PM
Norel's Avatar
greg
Let me guess, you have after market guage faces. Jerking is a common sign of needle stick-age. Take the dash apart and put more tape on it, or whatever, the face is rubbing against the needle. Mine does it in the hot weather too. Just part of the fun of having after market guages.
Old Jun 25, 2003 | 10:23 PM
Dev's Avatar
Dev
Andrew
if you find that the odometer stops along with the speedo, it could be the transmission sensor...which is located a few inches under the MAF sensor. im not sure what the technical name is...its a little black plug.
Old Jun 26, 2003 | 05:46 PM
Norel's Avatar
i belive the speed sensor is the one under the MAF
Old Jun 26, 2003 | 07:49 PM
maxspeed96CT's Avatar
The original VQ...
I got the same problem exept its with my tach, it works up to about 2k and works better when it feels like it. It realy pi$$es me off.Any body know if this is comon on 95-96's to?
Old Nov 15, 2003 | 08:23 AM
Jepht20's Avatar
Custom User Title...
did any of you guys fix this? i tried a spare gauge cluster i have and it still didn't work. would that make it the sensor on the transmission? i am not really comfortable driving around not know how fast i'm going and not putting miles on my car. help would be appreciated
Old Nov 18, 2003 | 06:09 PM
casanewt's Avatar
My odometer & trip odo have stopped working, but all the gauges are fine. Could it be the tranny sensor??????
...somewhere in the 92,000 mile range
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
Jigaa
Jan 3, 2001 01:29 PM
