Need Help with Tails
Old Nov 23, 2002 | 12:04 PM
macksima's Avatar
I know, I know, I got altezzas, they're rice, or whatever. But i got in a fender bender, and the altezzas were cheaper than buying new stock tails. So i got the altezzas, and realize that chrome altezzas are a bit too much on my black max. I want to do the skyline painting, but I don't want to paint the outside of the lens. What's the easiest way of getting the plastic off the taillight? Thanks for help.
Old Nov 23, 2002 | 05:29 PM
Dev's Avatar
Dev
im guessing it would be the same way as taking off the lenses on the stock tails. either put it in the oven, or use a heatgun/hairdryer to heat up the glue and carefully pry it off without bending it.
Old Nov 23, 2002 | 05:50 PM
StillenMax32
Re: Need Help with Tails
Yeah it should work the same way as cleaning the headlamps. Use a hair dryer or heat gun and heat up the glue seal and then see if you can get the cover off. Just make sure not to melt the plastic. And hey if it does not work go on ebay and get you some new ones for 150 bucks.
Old Nov 23, 2002 | 05:56 PM
95emeraldgxe's Avatar
why dont you want to paint on the lens??? it looks alot cleaner that way, and it is also much easier remove it
Old Nov 23, 2002 | 06:37 PM
metallic97gxe's Avatar
Master Will
just paint the lense don't risk taking it apart
Fbana41
Aug 29, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
4doorGTR
Sep 11, 2015 04:09 PM
Nitehawk11sv
Aug 31, 2015 02:43 PM
