Maintaince Question on auto tranny >>>>
Old Dec 29, 2000 | 11:14 AM
MAXDriver
How often do you drain-fill with new ATF ?
What other things do I need to do to keep my tranny lasts ?
Thanks All.
Old Dec 29, 2000 | 11:21 AM
Kenneth's Avatar
OG :)
Thanks All.
100k for the fluid refills... the filter is non-serviceable
Old Dec 29, 2000 | 11:28 AM
Daniel B. Martin's Avatar
Nissan does not include replacement of the automatic transmission fluid in any scheduled maintenance. However, it is cheap insurance to do so. Many owners like to make it part of their 60K service. You might want to change ATF even more often if you race, tow a trailer, or drive in mountainous terrain.
... What other things do I need to do to keep my tranny lasts ?
Install an auxiliary transmission fluid cooler. Refrain from abusive driving practices.
Old Dec 29, 2000 | 11:31 AM
Kenneth's Avatar
OG :)
Originally posted by Daniel B. Martin
Nissan does not include replacement of the automatic transmission fluid in any scheduled maintenance[/I]
i thought our fluid type lasts 100k per manufacturer spec...
Old Dec 29, 2000 | 11:46 AM
Kenneth's Avatar
OG :)
Originally posted by Murphy_TX_Mike
The filter is servicable. I have cleaned it without too
many problems. Clean it, and blow it dry with compressed air or replace it. It is held in by 8? bolts. It bolts to the bottom of the valve body.
87?! i see... you are right but i rather let a tranny tech do this... is replacement necessary, ever?
100K for a service seems high. I would recommend 40-50K, and that depends on how the fluid looks/smells and the type of driving you do.
was going by the fluid life... with a normally sane driver like myself shouldn't have a problem... inspect inspect
Old Dec 29, 2000 | 11:59 AM
AntGVR4's Avatar
I can't .. thas the problem ..
i empty whatever fluid comes out of the tranny pan during every other oil change..
loosen the screw on the bottom of the pan... about 4-5 quarts come out.. i figure if i do that every time eventually it will all get flushed..
Ant
Old Dec 29, 2000 | 12:30 PM
[/I]
This is a good practice. You are driving on cleaner ATF than most cars on the road. Keep up the good work!
Old Dec 29, 2000 | 04:34 PM
Eric L.'s Avatar
I get my ATF drained and refilled (3 qts) every 15k. It's pretty cheap (adds like $20 to the service) and good insurance for keeping your transmission in good shape. I recently had a full flush and refill with Redline D4 ATF, but for most people that's overkill. Expensive too ($200).
As for Nissan's interval, I don't think there is one. Every 30k should be more than enough if you don't beat your transmission.
Old Dec 29, 2000 | 05:57 PM
boogiemax95's Avatar
I do mine every 5000 miles
I drain my tranny pan every 5000 miles, which includes put in a new filter and cleaning out the pan to remove the excess dirt. I put in about 6 quarts every time. It just a safety issue for me.
Hey it is not so hard to remove the pan. Most people don't want the trouble.
Old Dec 29, 2000 | 06:12 PM
1MAX2NV's Avatar
Get a tranny cooler. Heat kills the fluid. Bad fluid leads to tranny break down. With a tranny cooler, you will get more out of your ATF.
I flush my ATF every 30K miles. It's overkill, but Maximas are notorious for auto tranny failure. Better spend $60-$100 get a flush every so often than paying $1K for a new tranny @ 100K miles.
Thanks All.
Old Dec 29, 2000 | 06:27 PM
MacGyver's Avatar
Doing a drain-fill on a 5spd is as flushed as it can get because you can't really pump it, right? Also, any ATF fluid will work for a 5spd? (is there some issue about zinc or something damageing the clutch...i was reading another post about that)
Old Dec 30, 2000 | 07:46 AM
The previous posts in this thread relate to automatic transmissions. You have introduced the topic of a 5-speed. Nissan recommends API GL-4 SAE 80W-90 gear lubricant for the 5-speed transaxle. There are some manual transmissions which use ATF, but the 4Gen Maxima is not one of them. The clutch is a "dry" mechanism. It does not come in contact with the transaxle lubricant, so the presence or absence of zinc in the lubricant has no effect on the clutch.
Old Dec 30, 2000 | 07:45 PM
MacGyver's Avatar
So, Daniel, you recomend just getting the fluid from the dealer? Or should i try to find some aftermarket/sythetic fluid? And drain/fill will do a good job since it is a 5spd?
Old Dec 30, 2000 | 08:02 PM
Kenneth's Avatar
OG :)
should last forever but...
i recommend redline for manuals
Old Dec 31, 2000 | 08:53 AM
Drain and fill is the right way to replace the lubricant in a 5-speed.
I do NOT recommend buying the gear oil from a dealer. You should be able to buy this product anywhere you buy motor oil. Any name-brand product will do. Just make sure the container says API GL-4 SAE 80W-90.
Some Nissan owners praise synthetic gear lubes such as RedLine. Others have reported axle seal leaks which started immediately after switching to synthetic. My own Maxima 5-speed is still running on the factory fill.
pktaske
May 6, 2016 07:49 AM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
