I have a problem with my brakes! can you help me identify it?
Old Nov 29, 2002 | 08:30 PM
silvermax2k2's Avatar
Hi guys.
here is my problem:
ok, i just bought my car the other day, and it just got inspected the other day too. it failed the inspection because it needed back brakes. so they put new brakes in it. but i think there is a problem... everytime i put i my brakes they squeel, and every time i put on my brakes harder they grind. (or make a sound/feel like grinding) so what is the problem? is it posiable that i have bad front brakes too? thanks.
Old Nov 29, 2002 | 09:06 PM
Shoooter_j's Avatar
I think its just how max brakes are. Mine do that too...depending on the type of pad you have. I went from stock to PBR Metal Masters...same situation...squealing and a quiet, but just noticable grinding sound, although I don't think they're grinding.
Old Nov 29, 2002 | 09:42 PM
pezking4's Avatar
Go check your local parts store and try some of the anti-brake noise products they have.
Old Nov 29, 2002 | 10:47 PM
Eric L.'s Avatar
It is important to use the stock shim kit (brake hardware kit). I believe teh nissan kit for the rear shims comes with a small pack of antisqueal goo.
Squealing is normal. Grinding is not. Make sure you mounted the pad correctly and that you do not have a warped rotor.
Old Nov 30, 2002 | 07:04 AM
njmaxseltd's Avatar
Squealing isn't normal
Grinding isn't normal
Quiet braking is normal
The most common cause of squealing brakes is the use of the proper shims and correct lubrication of the caliper pins. If either of these 2 key elements was not furnished, your brakes are going to make noise.
Mar 12, 2020 12:06 AM
follyburr
Detailing
Jun 13, 2016 02:06 PM
0m3nc0w
Sep 11, 2015 05:21 PM
bbsitum
Sep 11, 2015 04:55 PM
Colossus
Sep 9, 2015 05:46 AM
