Spark Plugs
Old Dec 2, 2002 | 08:28 AM
JiggsHall's Avatar
Spark Plugs
I want to give my Max a tune up , what plugs do you recommend. I want to use NGK Platinum +.
Old Dec 2, 2002 | 08:47 AM
Sprint's Avatar
http://forums.maxima.org/search.php?...der=descending
Old Dec 2, 2002 | 09:08 AM
JiggsHall's Avatar
Thanks !!!
Old Dec 2, 2002 | 09:43 AM
JiggsHall's Avatar
Sprint,
One more question, I took the MAX in for the alternator replacement under the recall and the dealer did a 27 point inspection. They said my tranny fluid needed to be changed, should I have them change it for $85? I'm having them change the OPS.
The wanted
$135 Accessory Belts
$95 Flush and Fill
$300 Fuel System Cleanout
Old Dec 2, 2002 | 09:55 AM
SuDZ's Avatar
Originally posted by JiggsHall
Sprint,
The wanted
$95 Flush and Fill
Do you have a 5 speed or Automatic?
SuDZ
Old Dec 2, 2002 | 10:01 AM
ejj's Avatar
ejj
SuDZ
I would assume auto. Manual tranny's don't require flushing.
Jiggs -
You could do the belts yourself for about $25 in parts if you're willing to, and I doubt that the fuel system cleaning will help, and I'm sure its not worth $300.
Old Dec 2, 2002 | 10:04 AM
Sprint's Avatar
Sprint,
The wanted
$95 Flush and Fill
belts are a b!tch.. but they are dooable..
tranny.. flush and fill is easy.. depending on what tranny you got.. you can find the instructions around here..
fuel system cleanout is i spoke to a service tech.. he said the fuel cleaner you buy at the gas station is just as effective as the one they do there...
if you havn't done plugs before.. check my site
http://sprint.happygrovealumni.com/tails/sparkplug.htm
Old Dec 2, 2002 | 10:05 AM
patel_anu's Avatar
I bought my NGK platinums from Advance Auto, 60 bucks total
OT. Is there a way to do the fuel system clean yourself?, how would you do it?...i'm sure theres a write up somewhere, If someone could post it, thanks.
anu
Old Dec 2, 2002 | 10:09 AM
ejj's Avatar
ejj
Nice write-up sprite. That may be the most detailed spark plug write-up around.
Old Dec 2, 2002 | 10:10 AM
Sprint's Avatar
Tranny Flush
http://forums.maxima.org/showthread....uid+and+amount
http://forums.maxima.org/showthread....anny+and+flush
I like the first one the best..
Old Dec 2, 2002 | 10:11 AM
Sprint's Avatar
thanks
Old Dec 2, 2002 | 10:14 AM
njmaxseltd's Avatar
anu
Goto www.motorvate.ca and follow the links for Throttle Body cleaning. This is really easy to do. After you complete that, dump a bottle of Techron fuel system cleaner in your next full up.
Total cost for your fuel system clean out ~$25 bucks.
Old Dec 2, 2002 | 10:24 AM
SuDZ's Avatar
yeah I know, I just wanted to make surethe shop wasnt trying to get him for things he does not need.
SuDZ
Old Dec 2, 2002 | 12:03 PM
JiggsHall's Avatar
This dealer does mechanical work excellent work , but they are notorious for how expensive they are. Dealers basically play upon peoples intelligence.Thanks for the help, and good information.
I'm still unsure of which plugs I should buy , because the opinions vary so much. I'll probably get the NGK Platinums.
Old Dec 2, 2002 | 12:16 PM
patel_anu's Avatar
Thanks for the link, but i followed the links to the throttle body and didn't find anything about the fuel system clean. Do you mean i need to just clean the throttle body and thats the same thing? and then add the techron stuff?...
anu
Old Dec 2, 2002 | 12:17 PM
Sprint's Avatar
NGK Coppers..
if you don't mind changing them in 30k then coppers are better.. much better spark.. cheaper.. check my site for PN
Old Dec 2, 2002 | 12:42 PM
JiggsHall's Avatar
Do you think that my local Autozone would have them ?
Old Dec 2, 2002 | 12:44 PM
JiggsHall's Avatar
www.motorvate.ca is an excellent resource.
Old Dec 3, 2002 | 09:29 AM
patel_anu's Avatar
Nope, Autozone doesn't carry NGK's
anu
Old Dec 3, 2002 | 09:35 AM
JiggsHall's Avatar
I guess I'll be making that dreaded trip to the dealer.
Old Dec 3, 2002 | 09:54 AM
Curt Deiner's Avatar
Don't do it! They wanted like $18 each when I checked. Talk to Matt or Jason at tustinnissanparts.com ask for the maxima.org discount and the oem plats are like $8 each, and no tax unless you live in CA. They will charge like $6 shipping.
Old Dec 3, 2002 | 10:33 AM
patel_anu's Avatar
And if you want them right now, go to Advance Auto, i paid 60 bucks for my platinums
anu
Old Dec 3, 2002 | 10:35 AM
ejj's Avatar
ejj
Those are for platinums, he's talking about coppers.
I get mine from advance auto parts. If they can't reference the plug part number, ask if they have NKG plugs for a 97 (I'd assume 95-99 are the same though) Altima. They are the stock plugs for it and many other Nissans. I think they charge around $1.50 or $1.99 per plug.
Old Dec 4, 2002 | 11:58 AM
JiggsHall's Avatar
Thanks for the tip, there's and Advance auto near me too. NAPA had the platinum for $12.59 each. I'm going to check out tustin nissan....thanks Curt.
Old Dec 4, 2002 | 01:19 PM
Tripower's Avatar
Sprint,
The wanted
$95 Flush and Fill
Funny, I also have a 97 SE and took it in for the alternator replacement and got the same line on belts and flush and fill. That must be their standard response to everyone going in for the recall!!
Old Dec 5, 2002 | 09:08 AM
JiggsHall's Avatar
The Dealer's service departments job is to charge inflated prices.
Old Dec 6, 2002 | 08:24 AM
JiggsHall's Avatar
What are the part numbers for the NGK platinums as well as coppers ?
Old Dec 6, 2002 | 09:08 AM
ejj's Avatar
ejj
Makes sense. Its a good way for them to recover some of their losses with the recall. I'm sure many people fall for it.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
