60k tune up TIME?????
Old Dec 3, 2002 | 09:34 PM
APER5's Avatar
hey whats up listen just wonderin, i know the tune is gonna contain:
1- spark plugs
2- oil change
3- fuel/air filters
4- flush out system
5- radiator coolant change
6- pcv valve
7- belt replacements(can be adjust but to make sure u could replace em at ur own option)
8- throttle body check/tweek...
??????????????BUT HOW MUCH IS THIS GONNA COST??????????????????????
WHETHER AT NIS.DEALER OR REGULAR SHOP....
NEED OPINIONS OR CONCRETE ANSWERS AS TO WHAT SHOULD BE EXPECTED ESTIMATED THAT IS..........
Old Dec 4, 2002 | 12:22 AM
ThurzNite's Avatar
tranny fluid, brake fluid, rotate tires. not sure what else...my local dealership doesn't do the pcv for 30k service...and they don't offer a 60k. I don't think i'll change mine, but i'm doing everyting you're doing...hopefully by mid dec i'll be done.
Jae
Old Dec 4, 2002 | 06:33 AM
Rogo02SE's Avatar
I wouldn't do numbers 7 and 8.
Rest of the stuff I would recomend you to do yourself.
With a repair manual and .org SEARCH option most of the stuff is easy to do.
Tranny flush you can do at any TRANNY shop it's cheaper then the Stealer.
Old Dec 4, 2002 | 10:36 AM
SuDZ's Avatar
Just do them at your own pace on your own. You will save some decent money that way too. Most of the things are really not that bad and can be done relativly easy.
SuDZ
Old Dec 4, 2002 | 10:44 AM
rbeyer's Avatar
My '98 Maxima is about to hit the 60k mark. Is the 60k service even worth it? I keep up maintnence very well and will still change plugs..filters..ect. I haven't searched, but what exactly needs to be done or checked in the 60k tune-up?
Old Dec 4, 2002 | 12:15 PM
ny96max's Avatar
when i hit 60k:
plugs
fuel filter
pcv
motor oil
tranny fluid
now im at 107k:
plugs
ALL coil packs
UDP and belts
coolant
brake fluid and ss lines
tranny fluid
motor oil
ALL fuel injectors(possibly)
Ant
Old Dec 4, 2002 | 01:09 PM
Joeycurl's Avatar
Re: 60k tune up TIME?????
1- spark plugs
2- oil change
3- fuel/air filters
4- flush out system
6- pcv valve
somewhere around $430 at a dealership or at a Nissan Master Tech shop.
Old Dec 4, 2002 | 02:32 PM
ThurzNite's Avatar
how important is the pcv to replace?
Jae
Old Dec 4, 2002 | 02:49 PM
Joeycurl's Avatar
Jae
When I took mine in they told me that I didn't have to change it out. I even said that the manuel said that it should be changed, but the guy was very insistant about it. He was/is a master tech from nissan and has his own shop that is registered with the BBB. I believed him for now.
Old Dec 4, 2002 | 03:22 PM
SuDZ's Avatar
I was told the same thing but figure if I change it now then I dont have to worry about it for a long time.
I guess the way the pcv is setup in Nissans cars is different from conventional methods. I am not sure how this is just what I was told.
SuDZ
Old Dec 4, 2002 | 04:00 PM
pmg's Avatar
pmg
I bought the pcv valve at autozone and a mechanic did it for $10. I tried but it's a real pain. Even the mechanic said it was a pain. BTW - the location shown in the chilton's manual is wrong.
Old Dec 4, 2002 | 10:55 PM
JPMax's Avatar
What's next!?..
Strange, I didn't find it hard at all to change the pcv valve. It actually took me all of 10 minutes to replace and it was my first time doing it.
Was the easiest part of the tuneup.
Just gotta know where it's located.
Old Dec 4, 2002 | 11:11 PM
ORBRIT's Avatar
I'm just doing my 60k now - before this I've never even changed the oil myself before on any car- I've done spark plugs though..
So far I've done:
Oil change $23.95 for 5 qts Mobil1 Synthetic 5W30
Oil filter change $11 for Mobil1 oil filter
Waiting to do this weekend:
PCV Valve $3
Spark plugs NGK PFR5g-11 $65 shipped
I checked the belts and they've been done recently - I only bought the car 2 months ago.
I'll do the manual trannie fluid and top up brake/clutch.
mvm062
Nov 30, 2020 09:00 AM
Finkle
Sep 27, 2015 09:53 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
