Reversed rear blinkers
Old Dec 7, 2002 | 09:37 PM
synix's Avatar
How would I go about setting up the rears blinkers on my '96 so they would stay on when I turn all the lights on and then blink normally when I perform a turn?
Did a search, couldn't find much (been having problems with the searches lately...not turning up things I KNOW I've found before).
Thanks.
Old Dec 7, 2002 | 09:57 PM
clee130's Avatar
Ummm ... why would you do something like this? Having your turn signals on all the time, annoying everyone behind you?
Old Dec 7, 2002 | 10:00 PM
synix's Avatar
I did the red-out. Haven't heard of this done before and figured it could be a fairly decent looking mod.
Old Dec 8, 2002 | 06:37 AM
njmaxseltd's Avatar
Illegal, your asking for trouble.
Old Dec 8, 2002 | 12:07 PM
SE Maxima's Avatar
i don't know, would this really be illegal? i think if the orange part were redded out it would probably look pretty cool to do what he's talking about. i don't see why it would be illegal either. plenty of vehicles (i'm thinking mainly trucks) have all red tails that have only one portion blinking when the signal is on.
as for doing it, i don't know for sure, but i would imagine it would just take some simple wire splicing/rewiring in the trunk. good idea.
by the way, which red-out method did you use?
Old Dec 8, 2002 | 02:51 PM
ThurzNite's Avatar
can you be more detailed on what you want? I'm currently rewiring my taillight, but don't want to disclose too much info (wanna stay original)
Jae
Old Dec 8, 2002 | 05:01 PM
xarfox
Jae
i know how you can stay original
put a big sticker on your car that says "IM AN IDIOT"
Old Dec 8, 2002 | 05:19 PM
MIXXMAX's Avatar
All you need to do is buy a 1157 bulb socket (double filament) and wire the parking light circuit to the lower wattage filament of the bulb, and wire the turn signal circuit to the higher wattage filament. I did this on my '95 when I had Alteezas. But, since the stock tailight bulb housing on the '95-'96's are wired in one unit, you will have to go around this by getting a 1157 socket so that you can wire both filaments on the bulb.
Old Dec 8, 2002 | 06:06 PM
synix's Avatar
Yes that was my original idea, but then at night, when my lights are on, I would have the problem of the blinkers blinking between the lower wattage filament and higher wattage filament instead of on-off-on-off; It would probably look like I'm braking.
Jae
I want to wire the rear blinkers so they'll always be on when I turn my lights on at night or whenever, but blink normally when I perform a turn. It's a pretty simple idea, the blinkers would just be reversed, but only when I turn the lights on. I wouldn't want them on during the day.
I used the paint from testors to red them out. Looks decent, but I think next time I'll try the tape. And no, none of this is illegal.
Old Dec 8, 2002 | 06:27 PM
MIXXMAX's Avatar
No, you shouldn't have a problem with blinking on-off, off-on, etc. You don't want the light to light up when braking, right? Like I mentioned before, the light will light constant under the low wattage filament side of the bulb (when the parking light circuit is on) and will blink bright when the turn signal is on. The higher wattage side of the bulb will always blink bright whether the parking lights are on or not. Trust me, this method works, because I had done the same.
matts95max
Apr 23, 2025 10:44 AM
minsbang
Sep 11, 2015 08:48 PM
bbsitum
Sep 11, 2015 04:55 PM
flu2000
Sep 8, 2015 02:23 PM
