Front & Rear Sway Bar Measurements
Old Dec 8, 2002 | 11:09 AM
RI-Max's Avatar
do the sell bigger front swaybars? and whats the stock size on it ?
i know stillen a addco only sell rear ones. how big are those?
Old Dec 8, 2002 | 11:28 AM
Vyrus's Avatar
The front swaybar is 20mm, and they do not make a bigger one. As head up, for a FWD car you'd actually want a smaller FSB to eliminate understeer.
The Maxima does not come with a rear swaybar from the factory. The Addco bar is about 22mm I believe, the same size as the Stillen one.
-Cyrus
Old Dec 8, 2002 | 11:35 AM
RI-Max's Avatar
hey thanx bro the only thing peeps do is buy new bushings for the front right? endlink and frame ones right?
Old Dec 8, 2002 | 01:40 PM
Vyrus's Avatar
You can buy polyurethane FSB end-link, FSB mid-bar, and control-arm bushings. Most people only have the FSB bushings because the control-arms are very difficult to replace and cause a lot of vibration.
-Cyrus
Old Dec 8, 2002 | 06:38 PM
Dave B's Avatar
Not DAVEB the parts guy
-Cyrus
Check again. Look up under the beam and you'll see a 38mm sway bar inside. The bar is then welded to the trailing arms.
Dave
Old Dec 8, 2002 | 08:25 PM
RI-Max's Avatar
it does have a bar??? i thought it didn't?
Old Dec 8, 2002 | 08:45 PM
96BLUMAX's Avatar
And dont forget about those new connectors that warpspeed is making. What were they called radial arm supports or something like that.
Old Dec 8, 2002 | 09:52 PM
brianw's Avatar
Yes, the rear beam technically does have a sway bar inside (as do all the Nissan cars with the beam rear suspension, I think... the SE-R Spec V is 38mm too), but it doesn't exactly do enough. Hell it doesn't do much, the Maxima understeers like a pig... which is why we buy the Addco or Stillen rear sway bar.
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
jerrod99_se-l
Aug 22, 2015 04:14 AM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
