Car keeps cutting off and slips in reverse any ideas?
Old Dec 8, 2002 | 10:11 PM
95MADMAX's Avatar
Sweet Moses this cant be good. Almost Every morning before school it does this and sometimes when Im leaving school. Ill start it and let it sit for a few before i go. Then when i put it in drive it just either cuts off or the rpm's drop it shutters then shuts off. It even does it once ive gotten moving and i stop at a light sometimes. Now the check engine light is on. If you have any ideas of what it might be let me know. HELP!
Old Dec 8, 2002 | 10:22 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: Car keeps cutting off and slips in reverse any ideas?
i just had a problem like that, same symptoms exactly, no cel tho.
High and low clutches were burnt, torque convertor cooked... turned out that the main reason was a seized valve in the valvebody....... either way, it's not looking like a cheap repair......
Old Dec 9, 2002 | 08:01 AM
njmaxseltd's Avatar
Pull the codes from your cars computer. Read the thread at the top of this forum entitled "My check engine light is on". Once you get the codes you can look them up in the thread below that one. A sensor has failed, the check engine light indicates a code is stored which will point you to the failure.
P.S. - There's nothing wrong with your transmission.
Old Dec 9, 2002 | 08:14 AM
turbomax97's Avatar
That's the exact problem I had with my car.
When you put your car into reverse does it stall? When you're coming to a stop while driving, do the rpm's drop to like 2 or 300 and cause the car to shudder, then it either cuts out or jumps back up?
Old Dec 9, 2002 | 11:10 AM
95MADMAX's Avatar
Yeah it does. Once I've been driving for a few minutes it usually stops doing that. Its just for the first 2 or 3 minutes of driving though.
Old Dec 9, 2002 | 11:11 AM
turbomax97's Avatar
If you're car is in warrenty still, take it to Nissan... Also what was the ecu code>?
Old Dec 9, 2002 | 04:02 PM
95MADMAX's Avatar
Yeah i think it is, so I'll do that. As far as the ECU codes go i have no idea, but if you find out let me know.
Old Dec 9, 2002 | 04:19 PM
turbomax97's Avatar
we can't find it out, you need to pull the codes from YOUR car... use the isntructions in the link above
Old Dec 14, 2002 | 11:33 AM
95MADMAX's Avatar
Yeah I'm retarded. Well i got the codes and they said it was improper shifting to 1st and 2nd gear(A/T). What could have caused this and what should i do about it.
Old Dec 14, 2002 | 11:55 AM
Sin's Avatar
Sin
Sounds like classic clutch failure within the automatic tranny.
Old Dec 14, 2002 | 12:01 PM
turbomax97's Avatar
i second that.
Old Dec 14, 2002 | 10:00 PM
95MADMAX's Avatar
oh well i guess it could be worse. How much do you think it would cost to have fixed.
Old Dec 14, 2002 | 10:08 PM
Sin's Avatar
Sin
Hit up ebay, and try to get a rebuilt tranny. Then call around for shops that will do the re n re.
Old Dec 17, 2002 | 07:21 PM
Campy's Avatar
Why not just drop the auto tranny and throw in a 5-speed?
Old Dec 19, 2002 | 08:27 PM
95MADMAX's Avatar
You cant just drop in a 5 speed. I dont got an extra 500-1000 dollars for the conversion. But you dont know how bad i want to.
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
spidgeon
Aug 18, 2015 05:46 AM
Trin1j23
Aug 12, 2015 08:31 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
