Some good 300ZX caliper info.....
Old Dec 10, 2002 | 12:51 PM
Aaron's Avatar
Langley AFB Sux
This is some general caliper info...not maxima swap specific.
Im going to do this conversion so I'm looking for all info.
I thought this would help explain the difference in the aluminum and iron calipers.....rotor thickness.....etc
http://importnut.net/300zxbrakeswap.htm
http://www.princeton.edu/~asad/zbrakes/
ZX Calipers on a G20:
http://www.conecrazy.com/project-g20/brakes.html
Basically some good pics of the calipers and stuff....
Part #'s
http://www.zilvia.net/installs/zbrakes/300zx.asp
Cheston's site has a write up as well.....
http://www.maximadriver.com/
PDM Racing.....Mostly for 240/Sylvia 300ZX brake coversion.....but you could buy the necessary parts here too I suppose.
http://www.pdm-racing.com/products/brakesz32.html
Another page..........its a Sylvia.........but again more info and good part numbers......There is also a link on this page detailing how to change out the pads on 300ZX calipers......
http://www.importcargarage.com/kings...gar/brakes.htm
Link to change pads.....
http://www.zhome.com/ZCMnL/PICS/Brak...BrakePads.html
Courtesy Nissans Z32 Brake parts page....
http://www.courtesyparts.com/z32_brakes.html
Here is a page detailing the 3000 GT VR-4 12.?? inch Rotor upgrade that can be done to ZX's........which will work on a Maxima as well. (providing you have wheel clearance for the larger diameter setup) Seems like alot of money for two brackets and some bolts and washers....
http://www.greggscustoms.com/300zx.htm
Hopefully these kind folks dont get PO'd at me whorin they're links!
Old Dec 13, 2002 | 09:57 AM
redmaxpa007's Avatar
i SeE what you did therE
thank you aaron
are ss brake lines have a different connector to the caliper..correct?
i will take pics tonight of our ss brake lines (sine i have a compete set sitting in my basement)
Old Dec 13, 2002 | 10:44 AM
Aaron's Avatar
Langley AFB Sux
Originally posted by redmaxpa007
thank you aaron
From what I understand our calipers use the banjo style fitting which will work with the 300ZX calipers......but Ive read a couple of places that using actual 300ZX lines is better. They actually have a flared fitting that threads right into the caliper.
Aaron
Old Dec 13, 2002 | 11:30 PM
Aaron's Avatar
Langley AFB Sux
Could someone put this in the FAQ?
Old Dec 14, 2002 | 07:01 AM
Aaron's Avatar
Langley AFB Sux
Added more links to more good info.....
More part #'s.....
More Pics.....
And a page detailing how to change the pads out on ZX calipers....
Old Dec 14, 2002 | 07:13 AM
More part #'s.....
More Pics.....
Old Dec 14, 2002 | 07:21 AM
Aaron's Avatar
Langley AFB Sux
I'm just trying to get as much info together so when someone asks...
"Will 300ZX calipers work.......yada yada yada"
They will have a crap load of info available..........providing they use the search......
Old Dec 14, 2002 | 07:29 AM
Aaron's Avatar
Langley AFB Sux
You know Jeff............you could add on to this when you try the ZX rear calipers.........since you have them............everything mounts the same right........its just a E-brake cable issue right......I do work Sheet Metal....and hand in hand with a Machine Shop.....(who will be the ones milling 3mm off my ZX rotors when I get em )
Old Dec 14, 2002 | 07:31 AM
once again...
once i try those rear calipers i will let everyone know... and you know this man...
Old Dec 14, 2002 | 07:34 AM
Re: Some good 300ZX caliper info.....
some one is "supposidly" going to make a bracket cheaper.. *cough.. Matthel Ma...*cough.. cough
Old Dec 14, 2002 | 07:45 AM
Aaron's Avatar
Langley AFB Sux
Re: Re: Some good 300ZX caliper info.....
Hehe.....I read that too.......That'd be sweet if he did. 3000GT rotors would be cool.....I'm trying to stay as stock/sleeper/stealth looking as I can. They might could be crammed under 16's
Old Dec 14, 2002 | 07:50 AM
Aaron's Avatar
Langley AFB Sux
once again...
Old Dec 14, 2002 | 07:52 AM
Re: Re: Re: Some good 300ZX caliper info.....
yes, that would be nice.. and BTW your e-mails keep coming back to me with no response..
Old Dec 14, 2002 | 07:59 AM
Aaron's Avatar
Langley AFB Sux
Re: Re: Re: Re: Some good 300ZX caliper info.....
Probably McGuire's crappy server...........Im surprised it hasnt gone down. I think its a 486 DX............12meg of RAM......
But they got Flat Screens!!
Old Dec 25, 2002 | 12:27 PM
Aaron's Avatar
Langley AFB Sux
Sticky this?
Maybe??
Old Dec 25, 2002 | 12:47 PM
96BLUMAX's Avatar
Yeah its a very good writeup.
Old Dec 25, 2002 | 12:50 PM
Aaron's Avatar
Langley AFB Sux
Tomorrow I will get some more brake part cleaner (ran out) and clean and remove the pistons and other hardware and take pics.....
I'll include that in this post as well
Aaron
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
dvcamp
Sep 18, 2015 10:17 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
