Fog lights dont work
Old Dec 14, 2002 | 07:00 AM
97MaximaSEinMIL's Avatar
Hey guys, looking for some help here. The foglights on my 97 SE dont turn on, never have, looked thru the manual for how to turn them on, then i tried it, still no luck. Anyone else have this problem? Also looking for a stock passenger side fog light as mine is slightly cracked. Thanks guys!
Old Dec 14, 2002 | 07:05 AM
mzmtg's Avatar
Minister of Silly Walks
Fuse
Old Dec 18, 2002 | 08:06 PM
DHC's Avatar
DHC
Re: Fog lights dont work
mzmtg,
That’s kinda a easy ‘shot’ don’t you think…. Granted, it “would be the first” thing I looked at, and would hope he did the same, so I’d more likely try the relay. You can generally look at the fuse to see if it’s blown/bad (or ohm it), but the relay is another story. If the fuse is good, I’d try swapping the relay and see if that works.
Old Dec 19, 2002 | 01:52 PM
Re: Re: Fog lights dont work
Which fuse is it? I never looked at the fuses because I never cared about the lights until now.
Old Dec 19, 2002 | 03:14 PM
DHC's Avatar
DHC
Re: Re: Re: Fog lights dont work
If yours is like mine (I have a 95), and the Japanese I’m sure it is, look under the hood; the “fuse box” is located on the drivers-side front (by the battery). The cover is labeled and will tell you which one it is, and the “relay box” is on the passenger side and labeled as well. The Owners Manual should help a little with finding these (and the other) fuse/relay boxes. Good luck hunting….
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
