aaa..Dome lights went out
Old Dec 16, 2002 | 12:30 PM
95GreekMaxSE's Avatar
i was screwing around with the front personal dome lights when i hear a lil pop noise and it went out.. at the same time all the others went out (center dome lights, trunk light).. fuse is not burnt... now wat??? the dash board lights still werk..everything werks excpet front personal dome, center dome and trunk light..
Old Dec 16, 2002 | 01:07 PM
MacGyver265's Avatar
What exactly were you doing with the dome light? If you shorted it, you could have done damage elsewhere in the circuit. Where did the pop noise come from?
Old Dec 16, 2002 | 01:26 PM
Replacing the bulb.. not knowing i had the switch in the on position..ligh went on for a sec then pop..all lights out.. its annoying to have no dome light..aa
Old Dec 16, 2002 | 01:52 PM
Double check fuses is all I can tell you. Check all the fuses in the fuse panel that have anything to do with lights. Other than that, check the actual contacts where the bulb goes to see if it hasn't shorted out on something. I've had this happen on other cars. If you can pull out the entire dome fixture and inspect the wiring, do that.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
