Has anyone installed a windshield wiper motor?
Old Dec 18, 2002 | 06:13 AM
maxfanfromohio's Avatar
Shiver me timbers.
My wipers stopped working and I was going to replace the motor. It looks like it just plugs in and bolts down. Any advice would be appreciated. By the way, I called my local Nissan dealership parts department and they gave me a price of $310. for the motor. There is one on Ebay for $15. and has no bids. What a joke!
Old Dec 18, 2002 | 06:24 AM
Mishmosh's Avatar
Re: Has anyone installed a windshield wiper motor?
The OEM part really shouldn't be that much... maybe they quoted you the wrong part...
http://forums.maxima.org/showthread....hreadid=119860
Old Dec 18, 2002 | 06:31 AM
Shiver me timbers.
Thanks for your info Mishmosh. I thought the price sounded high also, but with dealerships, you never know. You replaced the pump, I am replacing the motor. Do you think it will be just as easy? Thanks.
Old Dec 18, 2002 | 06:39 AM
Mishmosh's Avatar
Oh... shoot. My bad. You mean the actual motor that turns the blades and not the pump motor... Hmmm... maybe $310 isn't so far off!
Check out the price list sheet... the retail may be old but it gives you a rough idea. Maybe check out JRNissan for a discount quote too.
4th gen parts list here:
http://forums.maxima.org/showthread....hreadid=165498
Old Dec 18, 2002 | 06:48 AM
mzmtg's Avatar
Minister of Silly Walks
Have you tested the stalk? What about all the fuses and wiring?
You might want to evaluate these components before you replace the motor.
Old Dec 18, 2002 | 06:55 AM
Shiver me timbers.
I tested the fuse, it was ok. I just figured for $15. off of Ebay, I couldn't go wrong. It was a worst case scenario thing. I figured once I had them looked at, if they told me I needed a new motor, I would have one. When I turn the wipers on, I hear a noise that sounds like they are trying to work, but they don't move. I don't know what you mean when you ask if I have tested the stalk. Sorry.
Old Dec 18, 2002 | 07:20 AM
jiaxima96's Avatar
Sounds like motor is OK but the mechanic linkage is not. Something worn out that doesn't lock the motor to the blade?
Old Dec 18, 2002 | 07:24 AM
Shiver me timbers.
Are you saying replacing the motor wouldn't fix the problem? It is only $15. but if it won't fix the problem, I don't want to buy it. Thanks for you help.
Old Dec 18, 2002 | 09:07 AM
CalsonicSE's Avatar
Actually my car is at Nissan at this very moment getting it's windshield wiper motor replaced under warranty.
My wipers had completely stopped working. I could hear the wiper relay under the hood click on and off like it's supposed to, but there was neither sound nor movement from the wiper motor itself.
Turbo95Max helped me diagnose the problem and determined that the motor shorted out, and Nissan confirmed it.
Anyway, if you CAN hear the motor working but the wipers don't move then it's probably the linkage attaching the wipers to the motor. The wipers are attached to the motor via this ball bearing thingy. You can simply pop it back in if it popped out of place. It's probably not the motor if you can hear it. Check out the linkage first.
On a side note, the oem wiper motor does in fact retail for $200-$300.
Old Dec 18, 2002 | 11:20 AM
Shiver me timbers.
I recently had the windshield replaced in my Maxima. Before then, there was no problem, now there is. Do you think they screwed something up? I don't know if they did it or not, so I don't want to blame them. But it is ironic, isn't it? I will pull the wipers apart to see if it is an easy fix though. Thank you.
Old Dec 18, 2002 | 11:39 AM
MacGyver265's Avatar
Did it ever occur to anyone to check out a junk yard? If you are near a fairly suburban area, there should be a few junk yards with plenty of 4th gen Maximas. The whole unit should go for well under $100.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
JRod28
Feb 4, 2016 11:07 AM
jchronis2552
Aug 13, 2015 07:48 AM
