Sun Roof water leak help.
Old Dec 18, 2002 | 10:33 PM
crsh2's Avatar
I just recently found out the my sun roof is leaking water.
I really think its the rubber part arround the sun roof glass
but nissan does not sell just the rubber.
They want to sell me the sun roof it self for $445
and installation for $280.
This there away arround this journey?
Old Dec 18, 2002 | 10:36 PM
Aznwhitemax's Avatar
mayb u should find a nissan junkyard and c if u can find a salvage maxima and buy it from there
Old Dec 19, 2002 | 05:50 AM
njmaxseltd's Avatar
Water will leak through the roof. It's not made to be a perfect seal. There is a gutter that goes around the inside of your sunroof. Open it and look down into it. There are 4 drain hoses from that gutter, one in each corner. Make sure the gutter is clean and the drain hoses are not blocked. You can use compressed air to blow them out if there blocked. Once there cleaned out and draining properly, water will no longer come into your car.
Tom
Old Dec 19, 2002 | 07:26 AM
deezo's Avatar
The only way to see what's the problem is to take it apart and look. Save your money and just buy the parts you need. I rebuilt my cousins sunroof and it costed him $43 and a few hours of work. Tell the dealership to kiss your ****.
Old Dec 19, 2002 | 08:46 PM
crsh2's Avatar
Thanks for the respond. I really appreciate it.
njmaxseltd you have a great point im going to check it out tommorow
|Thanks
Old Dec 20, 2002 | 06:50 PM
dwreckp's Avatar
I had an '88 Alfa Romeo Milano that had a leaky sunroof. It turned out to be leaves clogged in the drains.
|Thanks
Old Dec 20, 2002 | 11:34 PM
happyricefob's Avatar
V^___^V
daymn my sun roof cover fly away while cruising down golden gate bridge. hopefully in the future there won't be sun roof leakage on me.
btw if any of u pick up around the golden gate bridge area sun roof cover please let me know and return it back to me, thx mucho!
Old Dec 21, 2002 | 08:46 AM
SamMan23's Avatar
no biggee. They don't do much for protecting your roof from leakage. Your sunroof has a whole drainage system like njmax said. Water is supposed to leak into your car with a sunroof, it just needs to drain out the sides of the car instead of into your interior.
I actually took the sunroof deflector off of my altima because I thought it looked better. I no longer have the car anymore and it's sitting in my closet.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
