Optima or Keep stock Battery?
Old 12-21-2002 | 06:51 AM
car123456's Avatar
A friend of mine owns a small auto parts store in central NJ. The other day he gave me a new Red Top Optima Battery, You guys think I should put it in my Maxima or just keep the stock one in it until it goes, the car is a 99se with 26K on it basically all stock but If it makes a difference I might install a Premier 12cd changer soon.
Also if you do think it's better then the stock one, if I disconnect the terminals on the Nissan Battery will I have to enter a code or password into the Bose radio to get it to function again. I have a 87 vette that requires this.
Thanks in advance
Chuck
Old 12-21-2002 | 07:26 AM
clee130's Avatar
Just keep the Optima as a spare. It's not worth it to take out your battery if all you have is a stock stereo.
And you won't have to enter any code to get the radio to function again - just have to reset the radio stations.
Old 12-21-2002 | 08:43 AM
MacGyver265's Avatar
I think Optima batteries are deep cycle batteries. You don't really want a deep cycle battery in a car because they are generally far fewer cold cranking amps than regular batteries. The thing that makes a deep cycle battery is the lead plates are thicker and are less prone to breaking down.
Old 12-21-2002 | 08:49 AM
packetattack's Avatar
I have an Optima Yellow Top in my Max, and it has more than enough rated CCA for starting the motor.
"In any vehicle or equipment that will use the battery only for Starting, Lighting, & Ignition requirements and has a properly working alternator, the OPTIMA Red Top Starting Battery will perform extremely well, often providing up to two to three times longer life than conventional batteries. If the vehicle has few or no after-market accessories and uses a stock or upgraded alternator, the OPTIMA Red Top Starting Battery is the appropriate choice.
Old 12-21-2002 | 09:29 AM
Quack 2x's Avatar
If you have it already, won't hurt to put it in. The Red Top is a good starter battery (it can start just about anything) and will last for many years. My Red Top is on it's second car already, and my friend's older style Red Top is still running strong after 5 years. It's been used pretty heavily, since he has a bunch of off-road lights, a Warn electric winch, and about 400 watts of stereo gear.
Aloha,
Quack2x
Old 12-21-2002 | 10:21 AM
Bad97MaxSE's Avatar
whats the difference bettween the yellow and red and blue ?
Old 12-21-2002 | 10:26 AM
Bad97MaxSE's Avatar
red= starter
yellow=deep cycle
blue=marine
thanks dude ...lol
Old 12-21-2002 | 11:16 AM
KFL's Avatar
KFL
Originally posted by Bad97MaxSE
red= starter
yellow=deep cycle
blue=marine
thanks dude ...lol
red-hids/amp/dvd
yellow-hid/amp/dvd/nav/amp/strobes/ps2/xbox/etc.
blue-got fins?
I say why not the battery is about 4years old nearing 5. It's a good battery overall
Old 12-21-2002 | 04:30 PM
dwapenyi's Avatar
HIDs don't use alot of power. In fact, they use less power than the stock headlight bulbs. The stockers have 45/65 watts, wheras an HID system is 35 watts. HIds use the same technology as a flourescent lamp. They need crazy voltage (like 25,0000) to get started for less than a second, but once lit, they're chillin'
DW
Old 12-21-2002 | 09:09 PM
TurDz's Avatar
DW
Good that you cleared that up. I know a lot of people don't realize that HIDs are power efficient.
Old 12-22-2002 | 12:23 PM
Bad97MaxSE's Avatar
so what are the built in amps for ?
Old 12-22-2002 | 08:49 PM
Dave B's Avatar
Not DAVEB the parts guy
1996 Maxima
stock battery
7 Midwest winters
still cranks away
I'm amazed this stock battery has lasted so long and apparantly I'm not the only one with a 7-year old OEM Nissan battery in their car.
Dave
Old 12-22-2002 | 10:42 PM
ThurzNite's Avatar
Originally posted by Dave B
1996 Maxima
stock battery
7 Midwest winters
still cranks away
Dave
that's awesome. congrats. My mom's 93 Previa stock battery went about 7 years, then we changed it just to be safe.
which optima is the best for an audio system when the car's off?
Jae
Old 12-22-2002 | 10:58 PM
Nismo's Avatar
Jae
I would say the yellow top deep cycle
Old 12-22-2002 | 11:08 PM
ThurzNite's Avatar
where's the cheapest place to get the yellow top?
Jae
JakeOfAllTrades
10-29-2024 06:55 PM
aw11power
10-10-2021 04:57 AM
06-06-2017 02:01 PM
gigabyte
01-06-2017 06:05 PM
jaydot901
09-29-2015 01:18 PM
Quick Reply: Optima or Keep stock Battery?
