Does y-pipe lose low end power??
i was looking into getting a y-pipe for my 98 max...i heard people say they lost low end power but gain toward higher end? how much is lost at lower end? i really want to improve in low to mid-range power...
Re: Does y-pipe lose low end power??
i def feel the loss of the low end and the significant gain of the high end. I'm gonna go on the lines of the loss of back pressure which is created from the stock pipe would have to do with that. The velocity of the incoming air probably isnt as strong with the free exhaust of the y pipe.
i saw some graphs of dynos....definetly well worth the $$$
Get it. Any loss in low end is quickly dismissed once you get above 4,000rpm. Also, if your state has vehicle inspections, for 96 and up they will only hook up your computer to see if it pulls codes, no sniffing. The Y-pipe is by far the best buy as far as mods and you should have no worries about emissions.
I noticed a little loss in low end. Actually, loss is too harsh of a term to describe it. Once you feel the gains after 3k RPMs, you won't even remember how the low end was before you added the pipe. I strongly recommend you get a ypipe. Go budget, no sound, all gain and its only $158!!! I have to admit its the best $158.xx I have ever spent.
Originally posted by Jamsan
the aftermarket y-pipes remove the 2 pre-cats that are found in the stock one...take a look at your stock y pipe, then look at the straight thru design of aftermarket ones, with NO cats....
If the person doing the inspection specifically knows that the Maxima has 2 pre-cats on the y-pipe, then your in deep ****...other than that, then you'll be ok...Just make sure your car is in full operating temperature before you go there....atleast drive around for 20-30 minutes before going
OT
I actually had my car inspected a couple of days ago. If it is 96 and newer all they do is read codes, in fact my Y-pipe was fine, but they did say that my headlights didn't pass. So while I was there I popped the old ones back in (I had them with me, and didn't even lock them in) after they put the sticker on, I pulled it into one of their parking spaces and put the Cuzo's back in
I was worried about my Y-pipe, now I'm not
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
