How do I change the engine oil?
Old Dec 23, 2002 | 09:44 PM
Max-2-GTR's Avatar
Is it better to change my engine oil by myself or bring it to the garage? since I can choose the oil I want. But the problem is that I don't know how to. It doesn't look too hard to change it but I need short directions. I know it's a stupid question but I'd like to know the answer.
Old Dec 23, 2002 | 09:46 PM
Jason R's Avatar
aka UNCDooD
actually you can choose buy the oil and take it to the garage and just ask them to use the oil you have provided them with. I've done it plenty of times. Now, I just get my frind who is a mechanic to change it for me and he knows what kinda oil i use so its all good for me. and, he even gets me free inspections as well but shhhh.
Old Dec 23, 2002 | 09:47 PM
nadir_s's Avatar
vicodin ... gift of life
Re: How do I change the engine oil?
ahhhhh i can't believe u asked a question like this. For the directions... please please search!!!!!!!!!!!
and for the opinionated question u asked... change ure oil urself! Do you run synthetic? If so, best to do it yourself. I know Wal-Mart changes synthetic oil for 30 bucks. Depends on how lazy u are really lol... but when it coem to my maxima, i do everything i can as much as possible.
Old Dec 23, 2002 | 09:49 PM
nadir_s's Avatar
actually, i've had a problem w/ that. I wanted the mechanic i usually take it to change it w/ synthetic but he said it was against policy or something. I've done walmart a couple times (when i absolutely didn't have time).
Old Dec 23, 2002 | 09:52 PM
Max-2-GTR's Avatar
What kind of oil should I use?
Old Dec 23, 2002 | 09:56 PM
Jason R's Avatar
aka UNCDooD
thats why you find a friend thats a mechanic that will change your oil if you let him make a pass at the track or just cruise down the street and back. lol
nadir_s's Avatar
what kind of oil are you running now? and how many miles do you have on your car. It's usually bad to switch from regular oil to synthetic... you might start leaking because the synthetic oil is thinner. When my car was new, it was switched to synthetic oil early so i've been running it on that since then.
Old Dec 23, 2002 | 10:01 PM
MacGyver265's Avatar
Step 1: Make sure engine is warm and car is on level surface
Step 2: find Oil drain plug
Step 3: Take drain pan, place under drain plug.
Step 4: Loosen and remove drain plug. Be careful not to drop in pan or you'll have to retrieve it later.
Step 5: Locate Oil Filter
Step 6: make sure there is something to catch the oil from under the oil filter
Step 7: Loosen Oil filter, allow oil to drain somewhat
Step 8: Remove oil filter
Step 9: After all oil is sufficiantly drained, replace drain plug and install new oil filter. (before installation, put a thin layer of fresh oil on the rubber seal of the filter.)
Step 10: refill with oil until the reading on the dipstick is acceptable. Should be around 4 to 5 qts.
Step 11: replace oil filler cap.
You're done, have a beer.
Old Dec 23, 2002 | 10:03 PM
nadir_s's Avatar
quick add-on to that, the drain plug and oil filter is located on the passenger side of the car and is covered by a shield that u need to unscrew and remove.
Old Dec 23, 2002 | 10:07 PM
There was actually a post earlier about a month ago where a knowledgeable member (White96MaxSE)of the board disputed the myths of Synthetic and Dino oil. In fact, this guy mixes Synth and Dino.
About halfway down:
http://forums.maxima.org/showthread....0&pagenumber=6
The next page too:
http://forums.maxima.org/showthread....0&pagenumber=7
Old Dec 23, 2002 | 10:53 PM
Max-2-GTR's Avatar
Well, I changed the oil at the garage so I guess they used the normal oil
Hein thx MacGyver265 for the directions!
Old Dec 23, 2002 | 10:57 PM
No problem... remember, those directions are not specific to just the Maxima, but nearly all cars. Thanks to Nadir for noting that the splashguard underneath the engine needs removing, I forgot about that.
Old Dec 24, 2002 | 07:02 AM
maxNYC's Avatar
For the spashguard, you dont need to remove it. Merely bend it back to reach the oil filter. all you need to do is get to the oil filter and do a swap while youre changing the oil.
TheMafia
Sep 4, 2015 08:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
