Adding Electronic Oil Presure Gauge
Old Dec 25, 2002 | 09:32 AM
mr300z87's Avatar
I have just become the proud owner of a 99 max SE 5sp car. It is a great auto, the only thing Missing is a OP gauge. I was surving the installation, I noticed that the Axle shaft Is very close to the location of the exisitng OP switch. WOuld like to use an Electronic gauge which have a much larger switch, this would most likely interfere with the axle. Looking for advice on this. So far my only compaint about the car is lack of gauges. My 87 max wagon had them????? Merry Christmas to all. Mike
Old Dec 25, 2002 | 10:27 AM
1MAX2NV's Avatar
Run a stainless steel braided line up to top part of the engine bay. There you will have plenty of room to mount the large oil pressure sender. Check out my pics.
http://imageevent.com/1max2nv/hksdinpanel
Old Dec 25, 2002 | 11:41 AM
96BLUMAX's Avatar
Checked out the pics, very fancy job. What is the tap in the big radiator hose for? I say you have tranny temp with the temp manifold and a ss line from the oil pan, but i have never seen the other one.
Old Dec 25, 2002 | 12:40 PM
1MAX2NV's Avatar
It's for the water temp gauge.
Old Dec 25, 2002 | 12:42 PM
96BLUMAX's Avatar
Oh i see. Isn't that what the gauge in the maxima already shows or is that coolant temp?
Old Dec 25, 2002 | 01:23 PM
1MAX2NV's Avatar
yeah..there is a OEM gauge but it's always in the middle. The water temp difference could be as much as 30 F. It's just more accurate with an aftermarket gauge.
Old Dec 25, 2002 | 01:46 PM
96BLUMAX's Avatar
Oh, i was never thinking of getting one because i thought the one in the car was good enough. So does the guage change actual readings while your driving?
Old Dec 25, 2002 | 03:17 PM
1MAX2NV's Avatar
Yes...you can see the temp go up when you are stuck in traffic. I can also tell when the cooling fan is about to turn on by the ECU.
Old Dec 25, 2002 | 04:12 PM
96BLUMAX's Avatar
Wow thats cool. I might look into that for my fourth gauge and its not that expensive too. Thanks.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
magiconthetire
Oct 26, 2015 09:03 PM
