PLEASE READ! Those with fog light rewire done
Old Jan 2, 2001 | 05:20 PM
Cutler's Avatar
I am replacing the bulbs in my foglights tomorrow with Hella yellowstars. My question, I understand that with this rewire you can run the fogs with the parking lights, but can you still cut the fog lights off/on with the factory switch, I mean that if one of the fog lights burns out I can cut the switch and the other one will be off. Please advise, my buddy has a 328is and is always giving me a hard time b/c he can run his road lights whenever he wants. Thanks in Advance!
Jason
Old Jan 2, 2001 | 06:20 PM
Rit's Avatar
Rit
YEp, they will be able to operate whenever you
have on parking, headlights or high beams on. Neat.
Old Jan 2, 2001 | 06:54 PM
wicked1044's Avatar
you can cut out the lights anytime you want. looks great at dusk/night. i have the yellowstars with superwhites. looks hot!!!
Old Jan 2, 2001 | 07:06 PM
Jimp
Where do you get the yellow lights? How much do they cost?
Old Jan 2, 2001 | 07:41 PM
wicked1044's Avatar
do a search.. sushanna(not spelled correctly)motorsports sells them. about 12 bucks
Old Jan 2, 2001 | 11:42 PM
ny96max's Avatar
got mine where WICKED1044 got his from, they were $12 each. They look really good at night. Better than the PIAA Ion Crystal ones, they were to pinkish for me. The only down side to them is that they look white from a far distance, but up close very yellow.
I actually ran all new wiring for my fogs and bypassed all the stock wiring. I used a heavier gauge with a lrger fuse to accomodate the x2 85watt bulbs. I also ran a new switch that i found right next to the dimmer switch and it looks stock. Having them wired this way it enables me to put them on with the car on or off and WITHOUT parking lamps. Looks very cool at dusk! Ill have pics up soon.
Old Jan 3, 2001 | 05:29 AM
1MAX2NV's Avatar
You could have just wired the signal wire to any +12v accessory. I wired it to a +12V accessory wire that's from the wiper relay. This way, you can still use the stock foglight switch to turn the fogs on or off regardless of the headlights or parking lights. If you forget to turn them off, it will go off when you turn off the car since it's +12V accessory like the headunit.
Old Jan 3, 2001 | 07:20 AM
goldmax's Avatar
Re: YEp, they will be able to operate whenever you
Does the "lights on" alarm still sound with the re-wire?
Old Jan 3, 2001 | 07:24 AM
Cutler's Avatar
Hella Yellowstars
The name of the place is Susquehanna Motorsports and the number is 1-717-993-2215, the guy's name is Ken Beard. I have the 55W versions and they cost $27.64 shipped. I hope this helps.
Old Jan 3, 2001 | 07:35 AM
Albertt's Avatar
Re: Hella Yellowstars
Yellow light is cool...I'm thinking about getting the 9004 yellow bulbs by Philips at this site:
http://www.autooptiks.com
Old Jan 3, 2001 | 08:42 AM
Bernie Lomax's Avatar
Re: Re: YEp, they will be able to operate whenever you
Yes, it still alerts you that the lights are left on.
-Sean
Old Jan 3, 2001 | 11:53 AM
goldmax's Avatar
Re: Re: Re: YEp, they will be able to operate whenever you
Thanks!
-Sean
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
