everytime I go in reverse or drive I stall
Old Dec 26, 2002 | 03:35 PM
vinny1978's Avatar
This morning it was cold and i have not driven my car for 2 days. It started a little hard but it started. When I would go into reverse it stalled immediatley and when i would go into drive it would stall. Once i let the car warm up for a couple minutes it was fine. Then my check engine light went on. Is it a fuel problem?? maybe?? Any help
Old Dec 26, 2002 | 03:54 PM
JsL's Avatar
JsL
Clean your Throttle Body.
Old Dec 27, 2002 | 10:49 AM
vinny1978's Avatar
Where can I find the directions? I know there is a sight with directions just don't know?
Old Dec 27, 2002 | 11:14 AM
Sprint's Avatar
if that doesn't work.. check for codes.. your tranny might be going..
http://www.turbomaxima.com/modules.p...iewlink&cid=25
Old Dec 27, 2002 | 11:16 AM
dvpatel99se's Avatar
Here
and ]I am your best friend dude
Old Dec 27, 2002 | 01:03 PM
Sprint's Avatar
Actually.. TB Cleaning is required when you take the car out of gear and its in Neutral and then it idles low and then comes back up.. this might be a transmission problem.. my friends car was doing this when the car was cold.. but once it warmed up it was fine.. ended up having to replace the tranny
Old Dec 27, 2002 | 01:04 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
exactly what happened to me... stalls while cold whenever put into any gear... Get yours checked out.
Old Dec 27, 2002 | 01:10 PM
Sprint's Avatar
did you fix it?
Old Dec 27, 2002 | 01:16 PM
turbomax97's Avatar
did you fix it?
yeah courtesy put a new tranny in for 50 bucks... they didn't notice don's little thingy in there
As far as I know, the clutches(high and low band) were cooked, torque convertor was basically gone... and a valve within the valvebody was seized...
Old Feb 2, 2003 | 01:27 PM
FLO_BOY's Avatar
I'm confused...a new tranny was installed for $50???
That sounds a little cheap...
FLO_BOY
Old Feb 2, 2003 | 01:28 PM
FLO_BOY's Avatar
FLO_BOY
under warranty...got it...
FLO_BOY
dcam0326
Sep 18, 2015 04:52 PM
97_GXE
Sep 15, 2015 06:47 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
minsbang
Sep 11, 2015 08:48 PM
