Idle Problem Please Help
Old Jan 1, 2003 | 06:39 PM
max7's Avatar
So I did my tune-up. Change plugs, fuel filter, and PCV Valve. I also changed my defective right bank O2 sensor. I cleaned and re-oiled the POP charger, cleaned the throtle body, and reset my ECU. Now when I start my car the idle is very high. 2K at times, when the interior fan is on, it even jumps around sometimes. It does this for some time and than it goes back to normal. Any input would be helpful. Thanks in advance.
Old Jan 1, 2003 | 08:24 PM
JUDE's Avatar
I don't know about idling high. If it was idling low/stalling, I would suggest the intake gasket. That's what happened to my Max.
Old Jan 1, 2003 | 09:03 PM
max7's Avatar
Thanks, I'm thinking if it may be from cleaning my throtle body.
Old Jan 1, 2003 | 09:04 PM
FLO_BOY's Avatar
Typically, when you clean your TB your idle will be higher.
When your ECU figures it out, your RPMs will drop.
FLO_BOY
Old Jan 2, 2003 | 02:13 AM
Nismo's Avatar
also its normal for high idle on cold starts. Mine is around 1.5k but not 2k so im not so shure
Old Jan 2, 2003 | 06:02 AM
max7's Avatar
Yeah my best guess is the TB cleaning, but I just wanted to see if it happend to anyone else. Thanks for the input!
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
