Best deal on brakes
Old 01-02-2003, 12:57 PM
I am Roid Rage
Bluebird's Avatar
Best deal on brakes
Here is the deal. I’m at 67K on stock brakes and its time to replace them. I want to go with a performance upgrade. However, big brakes are probably out of the question since I have to use the stock 16’s during the winter. So far, the best deal I have found is 4 slotted/drilled rotors with PBR/Axxis Metalmaster pads and SS lines for $360 + shipping from raceconcepts.com. So here are my questions.
1. Is there a better deal that I should look into?
2. There is a kit out now that lets you use 12.2 inch rotors up front with the stock calipers for around $400. Will that squeeze in under the 16’s?
I need to replace all 4 braking systems (front & back) and I’m willing to spend between $350 and $500, possibly a little more if I could use that 12.2 kit up front. Yes, I tried searching and I wasn’t able to come up with anything conclusive. Thanks in advance for your opinions and thoughts.
Bluebird is offline
Old 01-02-2003, 05:06 PM
infinit30t's Avatar
Re: Best deal on brakes
infinit30t is offline
Old 01-02-2003, 05:10 PM
thebigsadler's Avatar
The bigger 12.2" rotors may fit, but what's the point? You will have a bigger stopping area, but with the same stopping force. The rotors may last longer because heat can dispurse more throughout, but your braking force will remain puny (no offense). I would recommend the slotted/drilled combo for $360, it seems like a good price and you really aren't going to achieve much better braking without a bigger caliper to brake with.
Good luck.
thebigsadler is offline
04-16-2020 05:15 AM
06-06-2017 02:01 PM
leatherneck
09-30-2015 09:16 PM
HerpDerp1919
09-29-2015 02:02 PM
Socalstillen
09-26-2015 12:01 PM
Quick Reply: Best deal on brakes
