How do you know if you have "bees in a can" noise from y-pipe?
Old Jan 5, 2003 | 12:19 PM
athlon omega's Avatar
I got my Budget y-pipe installed two weeks ago. I am not too certain has to whether I have the "bees in a can" sound. The sound that I here at startup is a deep growl and also for the most part when I accelerate. The bees in a can noise is only prevalent at startup right? However, I tend to hear a lighter noise sound like a vibration from the silver part, flex section?
I took it back to the mechanic that installed it and found out that they welded the y-pipe to the pipe coming from the front of the catylitic converter. I could see a circular weld joining the two-pipes. I asked him whether it was the heat shield vibrating against the y-pipe, and he said that they remove the heat shield to prevent this. Moreover, the mechanic said that welding the y-pipe to the exhaust system is how it supposed to be installed. Could this welding be a reason for the noise?
I'm thinking that this noise is there becuase of the elimination of the two precats so that more air is pushed throuh the pipe causing this noise. I've been crusing around with my windows down trying to make up my mind as to what sound it is, even asking my sisters when they ride with me.
Old Jan 5, 2003 | 04:46 PM
Bump
I'm guessing it's my imagination since I read up on y-pipes so much before actually buying one.
Old Jan 5, 2003 | 04:57 PM
Sprint's Avatar
bees in a can is cause by an older flex section i think all the y pipe makers have fixed by now.. not sure.. but it sounds like if you get a tin can and some rocks and shake up the can
Old Jan 15, 2003 | 06:11 AM
Velcro's Avatar
Re: How do you know if you have "bees in a can" noise from y-pipe?
I personally think he installed wrong if he took out that flex pipe. thats is there to keep the engine from making the exhaust rattle and move
Old Jan 15, 2003 | 08:55 AM
JPMax's Avatar
What's next!?..
When the flex section in my stock Y pipe broke I got that famous bees in a can sound. Bzzz..
I actually only got the noise while driving. Never at idle or cruising. Only for the first 2-3 seconds after stepping on the gas, usually after a stop sign or light.
Old Jan 15, 2003 | 10:47 AM
BlackCat's Avatar
RIP '98 Maxima SE
I thought that this is a straight switch and bolt-on.
I just had my Budget installed last Saturday and I don't get any beees-in-a-can noise at all. Just a nice little growl.
Old Jan 15, 2003 | 01:23 PM
BlackCat's Avatar
RIP '98 Maxima SE
Re: Re: How do you know if you have "bees in a can" noise from y-pipe?
Check out the technical write-up on motorvate.ca:
http://www.motorvate.ca/auto/maxima/...dget_ypipe.htm
user 11122324
42
Jul 18, 2022 03:35 PM
Quickywd01
Sep 21, 2016 09:36 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
