K&N Panel Filter - Re-oil BOTH sides? -Or just the Bottom?
Old Jan 6, 2003 | 10:05 AM
KWheelzSB's Avatar
What are your opinions on this? The K&N directions don't say.
I'm concerned about over-oiling & causing problems with my MAF sensor, which is why I'm leaning toward Re-Oiling just the bottom (upstream) side of the panel.
When you Re-oil a cone Pop-charger filter, you only spray the outside, right? Should be the same idea for the panel, no?
Thanks in advance,
-K-
Old Jan 6, 2003 | 10:23 AM
1MAX2NV's Avatar
I just oil the outside on my CAI. If you have time, I would oil it up and let it sit overnight on paper towels.
Old Jan 6, 2003 | 10:39 AM
KWheelzSB's Avatar
Thanks. I'm not going to be able to let it sit overnight, but will shoot for a couple hours. K&N recommends allowing it to air-dry 20 mins., before element is re-installed.
Old Jan 6, 2003 | 10:49 AM
phenryiv1's Avatar
Mod her. Ate her.
You just do the outside on the panel filters as well. Also, just use a LIGHT coat...
Old Jan 6, 2003 | 03:16 PM
Eric L.'s Avatar
Well there really is no inside or outside if you look at the way the cotton mesh just follows the ridges on the metal cone. So I would spray on the outside - a light coat of oil, just enough to it will be red. Let is sit and soak for a little bit and let the excess oil drain off before reinstalling.
Old Jan 6, 2003 | 03:19 PM
Jeff92se's Avatar
I'm needing a caw
Just one side as everyone said. AND use a light coat. If there is oil draining off the filter, you REALLY overoiled the filter. To spray on the oil, spray as if using a spray can. Spray ONE light coat. Wait for 10 min and then spritz on any areas that are still "white".
Old Jan 7, 2003 | 09:41 AM
KWheelzSB's Avatar
Thanks, all
Got it done & re-installed. So far, so good.
Cheers,
-K-
matts95max
Apr 23, 2025 10:44 AM
GregL65
Sep 5, 2015 09:37 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
