Noise when I turn my steering wheel.
Old Jan 3, 2001 | 08:40 PM
MICHAELCORY's Avatar
Recently I have noticed that when I turn my steering wheel I hear a small gring but after a minute of drving it stops. What could cause this to happen and how can I stop it? Thanks in adavnace.
Old Jan 3, 2001 | 09:19 PM
Kashoggio's Avatar
dude I have the same thing. I am begining to think its the idle speed.
Old Jan 4, 2001 | 12:14 AM
SUR4MAX's Avatar
grinding noise.....
Could be from a busted CV boot. Check behind the two front wheels, there should be this thing that looks like a 5-spd shift boot. Turn your wheels completely to one side, then check. Having the wheels turned will expand the boot. If broken, need to replace asap.
Old Jan 4, 2001 | 07:04 AM
Sonic's Avatar
Same noise here. Do you need to to just replace the boot or clean everything out and then replace it?
Old Jan 4, 2001 | 12:31 PM
I know it is not the CV boot I know that sound. I think I may just need some power steering fluid. I will add some to see if that stops it.
Old Jan 4, 2001 | 01:39 PM
maxi-milliyon's Avatar
steering noise
Son I got the same problem with my 97 Max and it only happens when the car is dead cold in the morning. I did notice the power steering luquid was a little low, which I filled. It stated happening when it got cold.
Maxi-milliyon
Old Jan 4, 2001 | 01:48 PM
Kevlo911's Avatar
Kevlo for President
it happened to me a few days ago. it was the steering fluid. i filled it up. i went to go get my 60,000 mile service and told the dealer about it. he said a clamp was loose and it needed tightening.
Old Jan 4, 2001 | 04:38 PM
I filled up the power steering fluid and the problem is gone. Thanks for the replies to my problem.
Old Jan 4, 2001 | 06:38 PM
SUR4MAX's Avatar
CV Boot replacement
To answer your question... if you plan to do it yourself, yep, clean out everything, replace boot, and refill oil/grease that used to be there. OR any mechanic will know what to do.
Otherwise refill steering fluid.
matts95max
Apr 23, 2025 10:44 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
LtLeary
Sep 14, 2015 12:33 PM
I<3 A32's
Sep 10, 2015 11:07 AM
