clunking/grinding sound when car is in reverse
I been getting this weird clunking/grinding sound for quite some time now. Whenever I put the car in reverse, I would hear the weird sound. Just to clarify, this is when the car is in the reverse gear, not actually backing up. No matter if I go from Drive to Reverse, Neutral to Reverse, or Park to Reverse, I still hear the same sound. None of the other gears have that sound. I checked the transmission fluid, and it's fine. Ideas? Tks.
Do you have a strut bar? If so is it Loose? Does it come in contact with any part of the engine? Especially the AC line from your compressor. I had a simular noise when I shifted in reverse. So I tightened my Strut bar it and bent a ac line support to keep the line clear of the bar. Now no noise. Hope this helps
The sound is still there. I noticed something additional. Not only would I get the clunking/grinding sound when I put it in Reverse, the whole car would jerk for a split second. Could it be the engine mount or strut mount?
Originally posted by Cumalittle
reverse is ready to go....hope u have money saved up for a rebuilt...
You're kidding? My tranny? Hm...I really hope not. If that's the case, the heck with a rebuild...5spd conversion!
I would agree with the FSTB suggestion. I had a sound similar to what you are describing and basically the "bar" part of the FSTB had come lose and just needed to be re-tightened.
The other time I had sound issues with putting the car in reverse was when my parking brake cable snapped my my rear brakes froze onto my rotors. That sucked. However, where you live, I doubt that's your problem.
Originally posted by DCmax
Traitor.
Traitor.
lol...actually I'm kidding on the 5spd swap part. Too much of a hassle if you ask me. I rather just sell/trade the car and get another car with a manual tranny. I might just do that depending if it's the tranny that is the problem.
check your tranny case I, my tranny case cracked and it makes a clunk clunk noise in and out of gear.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
