fluid leak - help
Old Jan 8, 2003 | 01:11 PM
ymNA's Avatar
fluid leak - help
I see some fluid drippin down in this area, I checked the fuel filter but it's fine, I see the inner part of the turning rod boot (don't know the proper name) has some fluid around it.
Any idea where the fluid come from?
Thanks,
Old Jan 8, 2003 | 01:13 PM
mzmtg's Avatar
Minister of Silly Walks
You sure it's not water? That's where condensation from the A/C system drips. What kind of fluid is it? Describe the color, smell, etc...
Old Jan 8, 2003 | 01:17 PM
ymNA's Avatar
I am sure it's not water (haven't use the AC today). It look and feel like some type of oil, clear and has a hint of yellow in it.
I will clean that part when the engine cool down, it has a lot of build up in that area.
Old Jan 8, 2003 | 01:25 PM
njmaxseltd's Avatar
Your power steering system is weeping. Check the fluid level, but it's a bit low.
Old Jan 8, 2003 | 01:50 PM
jbreit's Avatar
could the transmission output seal be leaking and oil getting splattered around by the axle spinning??....if you have a 5 speed, that could be very bad news....
if it is your power steering rack that's not so bad...a lot of cars develope some amount of a leak.....power steering fluid is cheap, and you can buy a lot of bottles of it for the cost of a new rack, installation and an alignment.
good luck,
john
Old Jan 15, 2003 | 01:05 PM
Shannon and Ian's Avatar
Son of a *****, I just looked under my wifes car today because there is fluid under it and guess what? Steering rack, left side is leaking. The resovior was low on steering fluid too. Our car has 90K on it. I wonder if 4G Maximas let go their steering rack at this age? Ours is a 97.
I am going to post a thread asking who had theirs replaced other than Nissan.
I replaced the rack on my NX2000. What a PITA. And it has a knock in it when I turn slowly to the right. I hate rebuilds but @ $800+ for a dealer rack new I will take my chance.
Old Jan 15, 2003 | 03:40 PM
JdawgX's Avatar
I also have a 97. My rack has been leaking for about 6 months now as well. This car is out of here! Reliable???? LMAO! Yeah, teh trannys suck (replaced my bearings recently), the rack is leaking, the power steering hoses had to be replaced due to improper install from the factory, the alternator had to be replaced due to a fire hazard.....
Yeah, GREAT car! It's for sale if anyone's still interested
Old Jan 16, 2003 | 04:23 PM
OK, here is the results of me looking under the car. The return line of the steering rack. The clamp was loose. I tightened it up with a 10mm socket. I was at the dealer getting parts for my NX and my buddy who works in service told the that Nissan had a voluntary campaign to tighten the hose for free. I checked in service but my VIN came up negative. It didn't matter cause I did it myself. So check the return line and after you tighten it up wash the area down and watch it for a few days. I will be checking it in a few days.
Old Jan 16, 2003 | 06:26 PM
ymNA's Avatar
Great, I'll check down there when I have time, and hope it's just a lose hose.
Old Jan 22, 2003 | 02:54 PM
Any luck?
Old Jan 22, 2003 | 03:26 PM
ymNA's Avatar
Any luck?
Well I took pics of the problem area, and you can find them here
Link to post
Look like i have to take it to the dealer, looks pretty bad.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
