how difficult is it to change a starter?
my mom's 95 SE's starter let go on us a few days ago. i'm probably going to replace it myself since we don't feel like get ripped off by the dealers. approximately how much does one go for at a parts store? is it difficult to change? the only good thing i see right away is it's in plain eyesight and not too tucked away. thanks for advice.
$140 at Autozone. Make sure you get the one with 10 teeth. More reliable.
If I remember correctly(replaced mine 2 months ago), you'll need a 12mm socket and a 17mm socket. Breaker bar or pipe to slip over the rachet will probably be needed for the 17mm bolt. It's on pretty tight. Large torque wrench may work too.
Took me only 10 minutes once I got that 17mm bolt to move.
Re: how difficult is it to change a starter?
I just changed the starter on my 97'SE last month. It was starting to hang and eat up my flywheel when starting. I got the one from Autozone because they were open at 3:00AM when I decided to change it. You gotta take the airbox and most of the intake duct work out, plus the battery if you want some extra wiggle room.
The guys are right....the second bolt (the bigger one) was a pain to get out.... you will need a breaker bar to get enough leverage. Otherwise its a walk in the park....
Originally posted by 96shogunmax
Please dont buy the autozone starter. Try Napa or Carquest or something like that. You will be replacing the Autozone one again.
I have an Autozone starter in my '95 and have been running with it for almost two years/20k mi with no problems so far.
Originally posted by Maxpower96
The 10 teeth starter applies to Maxs that were produced after June `96. Earlier maxs require 8 teeth. The best thing is to look if ur original starter has 8 or 10 teeth and get the same number.
Originally posted by KWheelzSB
Details? Did one fail on you? If so, after how many miles?
Well not with this car , but with others I have experienced failure. Like alternators lasting only 2 to 3 months. Same with a starter I bought. Lasted about 3 months. But this important "everybody has their own experences" . I mean its your car get what you want.
I wouldn't assume that your starter is bad because it is hanging in the flywheel. Mine was doing the same thing. I took it off removed two back 10mm bolts and then the solenoid on the side. The lower gear and rotating assembly grease was dried and the shaft wasn't moving on the innershaft. A little axle grease, wd-40 and about 45min saved me $140, and a trip to the autoparts store. Most importantly I didn't replace my high quality Japanese starter with some American rebuilt crap. Look at motorvates site it will give you some good advice.
i work at autozone and for the amount of starters we sell we dont get many back. if you do buy one from there though i would have them test if right outa the boz and make sure everything works right off the back. most of them we return are within the first few days or after a few years. biggest thing to check is how many teeth the starter has. i was gunna replace mine and checked every one we got in for the max and they all were 8 tooth starters. good luck man
linney
Many of us have bought from Walter Linney who owns Linney Auto Electric in NY. He lists on Ebay and you get a brand new Prestolite starter, 10 tooth, for $129. No need to worry about core, reman or anything. I have one in my '95 and think it is great.
Originally posted by finny
i work at autozone and for the amount of starters we sell we dont get many back. .... i was gunna replace mine and checked every one we got in for the max and they all were 8 tooth starters. good luck man
Originally posted by Rickalodeon
I still don't quite grasp the mechanics behind varying the number of starter teeth and their ability to mesh with the flywheel teeth. Anyway, everything works fine.
(Ie: they're not squeezing 2 extra teeth into the same space once occupied by 8, they're making the hub/shaft larger in diameter, to accomodate the extra teeth without changing the tooth size).
"Mechanical advantage" -so everyone has a better understanding of why this design was changed. . .
Simply put, the more teeth on the starter drive gear, the more "leverage" the starter motor has to turn the engine. In turn, less operating load is placed the starter motor.
Think of it this way: 10-speed bike. Rear sprockets, stacked together like discs, bigger to smaller.
Does it require less effort to pedal the bike when the chain is on the big sprockets, or the small sprockets? The big sprockets, of course.
Why? More teeth = greater mechanical advantage
I will gladly defer to your understanding, but your example still seems counterintuitive to me...I would liken the starter teeth to the front sproket of a bike (that which is applying the energy), and the flywheel to the rear sprockets. In this analogy, the fewer number of teeth and smaller sprocket diameter (or starter), the lesser amount of energy required to turn the "receiving" sprocket (or flywheel). However, as with the bike, the less energy translates to more revolutions. i.e. It would take more revolutions of the starter with 8 teeth [than one with 10 teeth) to move one full revolution of the flywheel.
This has me wondering if it was in fact the goal of the Nissan engineers to design a new starter motor that would yield a longer service life not by virtue of requiring the motor to undergo less load, but by virtue of it having to operate at an overall lesser duration of time. Theoretically, the 10-tooth motor should help the engine turn-over fractionally quicker than the 8-tooth motor, right? Over a lifetime of starts, maybe this saving in operational time is where Nissan found the extra longevity (?) Hmmmm. . .
Does the Soleniod come with the Starter??
When we're talking about the starter, does that include the solenoid? Do the starters you buy at Autozone and Advance come with the solenoid attached to it?
I have to replace my starter today, b/c it is spinning and not engaging to the flywheel. I was just wondering if I should buy a starter, solenoid, or both. Any answers????
Re: Does the Soleniod come with the Starter??
Re: Re: Does the Soleniod come with the Starter??
Yes and Yes.
Yes and Yes.
Re: Re: Re: Does the Soleniod come with the Starter??
Thanks for the help. Does this sound like I need to replace the starter of just try to regrease it? My battery is fine, but I've been having that famous starter noise for a year now. As of yesterday, it won't engage to the engine at all. The starter is just spinning and making a real fast winding noise. Thanks for your help again.
, hope it dont break or we will be back at autozone
homewrecker
Sep 23, 2015 03:41 AM
