you lowered your car, right? so, can you help a brother out?
Old Jan 13, 2003 | 09:07 AM
FLO_BOY's Avatar
hello all:
OK -- while it's still snowy and cold out, I am prepping meself for
lowering my ride this spring. Currently, I have about 115K miles, and
I want to replace everything rubber (lots of salt on Toronto roads)
and basically return my suspension to about as-new as possible.
That all said, I've been trying to compile a list of parts I need,
but there are conflicting part numbers and the like. So -- I have a
favor to ask:
If you've lowered your car, can you PLEASE post what you changed, as
well as the part numbers? I would REALLY REALLY appreciate it.
So far, I have the following info:
FRONT
Dust Covers
OEM "spacers"
front strut spacer -- 54329-39U00 (6.61 each)
front strut bearing -- 54325-5V000 (13.73 ea)
front strut dust cover -- 54050-31U01 (10.69 ea)
polyurethane sleeve -- 54034-85E10 (6.00/ea - 6 needed)
REAR
OEM "spacers"
strut spacer -- 56218-61L10
dust cover (boot) -- 55240-01a00
rubber seat -- 55034-31U00
polyurethane sleeve -- 55031-33P10 (6.63/ea - 2 needed)
cover washer -- 55248-01U00
more: front sway bar end link bushings
helical split electrical wire wrap (1/2" inside diameter)
MUCHOS GRACIAS!!!
FLO_BOY
Old Jan 13, 2003 | 09:12 AM
Lime's Avatar
I recommend going to polyeurethane dust boots instead. Summit has them, and if you get AGX you can get the AGX ones...same thing. You can even get yours in pink through Summit.
btw, it's muchAs gracias.
Old Jan 13, 2003 | 09:13 AM
FLO_BOY's Avatar
Summit? Lime -- can you help me out -- never heard of 'em...
MUCHAS GRACIAS
FLO_BOY
Old Jan 13, 2003 | 09:28 AM
GaMax97GLE's Avatar
Also:
4 Front Spring Isolators P/N 54034-85E10 $6.55/ea
4 Rear Spring Isolators P/N ________ $4.95/ea
Old Jan 13, 2003 | 10:45 AM
njmaxseltd's Avatar
Replace all the isolation sleves, 4 in the front (2 each spring) and 2 in the rear (only 1 each spring)
Replace the strut bearings
Replace the dust covers
The spring spacers might be in good shape still, but your not going to know until you take it apart. If anything, get 2 new ones for the front, the rears should be just fine.
There's a red gasket that goes between the strut mounts and the body of the car. There really thin paper junk from Nissan. The rears usually come out egg shaped too. Go to an automotive parts store and pick up a sheet of intake manifold gasket paper. It's about 2mm think. Cut out new gaskets to go on top. Do this for both the front and rear. It makes your car ride quiet over cracks by providing better isolation between the suspension and the body.
Here's some pics of the fronts the I made.
Old Jan 13, 2003 | 10:36 PM
FLO_BOY's Avatar
I made a web page...
to act as a "new post"...please check it out!
suspension
thanks!
FLO_BOY
Old Jan 13, 2003 | 11:05 PM
95emeraldgxe's Avatar
MUCHAS GRACIAS
FLO_BOY
summitracing.com
Old Jan 14, 2003 | 05:00 AM
Lime's Avatar
sorry, yes, that url is right.
And I recommend checking out the Radio Shack black coil-wrap instead of OEM isolation sleeves.
Lakersallday24
Jun 16, 2019 01:35 AM
twotonezed
Aug 16, 2015 08:10 PM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
dauntlessmax
Aug 5, 2015 10:29 AM
