Need serious help with hesitation???
Old Jan 13, 2003 | 08:27 PM
maximamoose's Avatar
Car feels like i havea tranny problem!!!
About a month ago, my car started to hesitate when i gave it some gas. I have a 5 spd, and it would do it while in gear, obviously! It would jump about 500-700 rpms, and go back down about a half second later. NOW, it jumps about 1500 rpms when i give it some gas. I don't know what to do, and I have no ideas as to what it could be. Can anyone out there help me out??? Also, from a stand still, it takes a litle extra gas anymore to get going. Please help me. BTW, mods are frankencar intake, wpspd y and b pipes. Thanks again.
Matt
Old Jan 13, 2003 | 09:50 PM
WizzaMax's Avatar
First and easiest thing to check is for vacuum leaks around intake between MAF and throttle body
...then check fittings and all plugs/sensors in engine bay to make sure they are all plugged in tight
...then check/replace fuel filter
...inspect tb inside for build-up...clean if necessary
...pull spark plugs and look for damaged electrode
get compression test on cylinders since plugs are going out anyway.
Good luck!
Old Jan 13, 2003 | 10:18 PM
WizzaMax's Avatar
Good luck!
Old Jan 14, 2003 | 04:54 AM
Good luck!
thanks. i'll check these out today after i get home. any other advice??? so, do you think it could be the tranny??? thanks again!
Old Jan 14, 2003 | 07:38 AM
funnylittlman's Avatar
Re: Car feels like i havea tranny problem!!!
Matt
a 500 to 700 jump would be something like the a/c compressor kicking on.
How about coils? You having any rough idling?
Old Jan 14, 2003 | 05:58 PM
Re: Re: Car feels like i havea tranny problem!!!
no rough idling. idle around 800. does anyone here have the frankencar intake? if so, is one of the hoses pinched about half it's normal size? the one in the back of the engine bay is pinched for me!!! would that be the problem, perhaps??? Thanks again
Old Jan 14, 2003 | 06:21 PM
Street Reeper's Avatar
Handsome
Re: Re: Re: Car feels like i havea tranny problem!!!
Could be. I never tried to drive like this, but to settle a bet I disconnected the vaccum lines and it idled pretty low. Did you use your original lines with the franken? You can get 5/8 hose at autozone for cheap, if you measure before you go, they can cut it for you. This may not be your problem but it is inexpensive enough to just go ahead and try.
Old Jan 14, 2003 | 06:27 PM
Re: Re: Re: Re: Car feels like i havea tranny problem!!!
well, i used the one from frankencar. it is too long. but, i think if i cut it down, it will also crink up. I don't know! I will give anything a shot at this point.
litch
123
Jan 4, 2024 07:01 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
trungg86
Sep 4, 2015 04:58 AM
