Jacking Point for Maintenance
Greetings!
I've had my 95 SE for about 2 yrs and have always done my own maintenance. I have yet to find a good point to "jack" from or place the jack stands to pull the jack.
Thoughts?
Thoughts?
Re: Jacking Point for Maintenance
You can jack the car up using the front cross member. Look under the car from the front you will see a large metal beam that goes towards the back. You can put jackstands on the inside of the control arms. Use common sense. For the back, you can jack up the car from the rear beam. You can put the jackstands on the rear beam also. If you have a aftermarket RSB that covers the rear beam. Use a piece of wood to wedge between the bar and the beam then jack up from the bar. Enjoy jacking your car. Hahaha.
Originally posted by mechanicaljoint
Greetings!
Thoughts?
Greetings!
Thoughts?
my03maxima
Jul 28, 2024 07:40 AM
TKHanson
Nov 24, 2018 01:39 AM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
