after engine start up sound???
Old Jan 15, 2003 | 03:21 PM
masterjoe's Avatar
hello was wondering if anyone can give me a answer to this sound problem?
i have a 99 max sel with 65,000 mile on it and when i started the engine it started up good and as soon as it started the engine it made a whirling cranking sound like a motor spining the sound came from the front near engine but cant pin point it does anyone have similar problem?/ or know what it could be ???
Old Jan 15, 2003 | 03:37 PM
JPMax's Avatar
What's next!?..
Does it happen everytime you start it or just the first time in the morning?
If it happens everytime, that would be easier cause you could have someone start the car while you're standin in front with the hood open to listen.
Is it a grinding kind of sound that last for maybe 2 seconds or more of a squeeling kind of Eeeeeeeee sound?
most likely suspects:
starter
alternator
loose belt
Have you done any engine work to your car recently?
Old Jan 15, 2003 | 03:48 PM
Eric L.'s Avatar
Depends what the sound is.
1) If it goes "voooo" then its probably the starter failing to disengage. If this is the case, regrease your starter following the directions on www.motorvate.ca to see if that helps
2) If it sounds like "screeee" then its a loose belt. You will need to tighten the adjustments nuts for the belt tensioner if this is the case, or just replace the belt entirely
3) Lastly, it could be vacuum leak, which would be the hardest to diagnose.
maxinout93
Oct 27, 2015 01:29 PM
conansriver
Sep 3, 2015 06:38 AM
seesole
Aug 26, 2015 11:22 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
