Bad sounds whem I turn hard
Old Jan 16, 2003 | 06:05 PM
cantgofast's Avatar
In order to park in my garage, I have to turn pretty hard. When I did it the other day, I heard two very loud and distinct noises, almost like cracking noises. I had no idea what it was. Sounded like it came from the front left. Anyone have any ideas as to what it may be?
Old Jan 16, 2003 | 06:07 PM
jamier2's Avatar
If it's popping while your car is rolling with the wheels sharply turned, it is likely the CV joints going bad.
Old Jan 16, 2003 | 06:09 PM
cantgofast's Avatar
I had breifly thought of that. Thanks so much for responding! I will get it checked out to make sure.
Old Jan 16, 2003 | 06:51 PM
TheMax95's Avatar
This has constantly been happening to my max ever since I replaced both axles with brand new ones. I've been driving with it like 1,500 miles. It only makes the sound when I cut the wheel a lot, esspecially on the left turns.
My brother, who installed them for me, says it could be from a dust collector or something that is rubbing against the axle when I cut too much.
Old Jan 16, 2003 | 07:20 PM
jamier2's Avatar
I'd say that isn't likely (my opinion) because the OEM axles didn't rub, did they? If they didn't, and if the new ones were installed right - i.e. no dust shields left loose, etc., then the new axles should not rub anything.
I have seen new axles that didn't come with much grease at all in the CV joints. Pretty crappy when that happens, but it is a possibility.
Old Jan 16, 2003 | 10:29 PM
lilharv321's Avatar
Re: Bad sounds whem I turn hard
I have what sounds like a rubbing noise coming from right front tire. I was told that it is most likely the front strut bushing. A fairly cheap part with labor should not be more then 100 bucks.
Old Jan 17, 2003 | 12:17 PM
Lushka16's Avatar
I have a similar problem with sharp turns.. it's a clicking noise whenever I turn the wheel all the way. Sounds like what you guys have (?). My old car had the exact same problem, I was told it was the tie rods. Maybe that might help some
-E
tsi6001
Oct 3, 2022 10:23 PM
A32goldylocks
Sep 2, 2015 06:39 AM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
follyburr
Aug 7, 2015 09:50 PM
