Rear Spoiler
Old Jan 5, 2001 | 10:03 AM
max96gxe
how do you get at outer two screws to hold on rear spoiler of 96 maxima? there are no access holes on outer edge of trunk. do you drill holes or remove rear light assemblys or is there a trick to installation.
Old Jan 5, 2001 | 10:06 AM
PiotrC70's Avatar
Okay, by now you've removed the 4 (inner screws)
that hold the spoiler on. The outside is held on by 4 clips.. 2 on each side. It doesn't seem like it but it is... I recommend after you remove the screws, to shut your trunk and do the rest of the pulling that way so you don't rip off the spoiler and kinda recoil and hit the trunk cause you'll scratch the shiet out of it...
good luck.
Old Jan 5, 2001 | 01:03 PM
max96gxe
Hi PiotrC70,
the spoiler is a new installation, no holes are in the trunk lid yet. do these clips go in from the outside top of trunk?
Old Jan 5, 2001 | 06:35 PM
PiotrC70's Avatar
I don't recall being able to see the clips from the inside of the trunk so..
To my knowledge, the square clips (hopefully you have them from the dealership) are attached from the outside. I do believe they are glued in or something because when I ripped off the spoiler after taking off the bolts, the clips stayed on the trunk. I'm assuming you bought a spoiler from the dealer or something so you should have the clips, seals and stuff... good luck
matts95max
Apr 23, 2025 10:44 AM
GregL65
Jan 17, 2020 08:01 PM
bbsitum
Sep 11, 2015 04:55 PM
jds22
Sep 4, 2015 01:52 PM
