3000 Rpm Idle!?!?
Old Jan 18, 2003 | 11:40 PM
plurco's Avatar
3000 Rpm Idle!?!?
Twice today and once a couple days ago I cranked my car up and it imediately idled up to 3000 RPM's then over the next 20-30 seconds went back to the normal cold idle speed. Anyone encountered this before? Nothing else seems odd with the running of the car other than this. Does not seem to cause anything bad, but I was just wondering if this was a sign of something starting to go wrong.
Old Jan 18, 2003 | 11:47 PM
Nismo3112's Avatar
Custom User Title
Clean your IAC valve.
Old Jan 19, 2003 | 12:03 AM
KWheelzSB's Avatar
Re: 3000 Rpm Idle!?!?
If this is occuring after the car was already warm (IE: went on an errand, parked, got back in, started up, 3000rpm. . .)
-then it could be a sign of a faulty ECTS (engine coolant temperature sensor)
If it's happening cold or hot, you might try cleaning your throttle-body 1st & see if it still misbehaves.
Also, see:
http://forums.maxima.org/showthread....hreadid=104931
Old Jan 19, 2003 | 12:23 AM
plurco's Avatar
just cleaned TB last week. It does not happen when it is totaly cold. If memory serves me right eack time was about 30 minutes to an hour after I had driven the car.
Old Jan 19, 2003 | 12:25 AM
plurco's Avatar
also all 3 times it happened while parked at my house where the car sits uphill. This might matter, might not, just thought I would throw that in.
Old Jan 19, 2003 | 12:33 AM
KWheelzSB's Avatar
I'm gonna stick with ECTS, based on your reply.
Pull the codes from the ECU & see if you come up with anything. . .
Try unplugging the ECTS wiring harness and plugging it back in (freshen up the contacts)
Also, you could treat the harness contacts with dielectric grease to enhance conductivity.
Test the ECTS, using a multimeter.
Report back - this is your mission, should you choose to accept it. Your mouse will self destruct in 5,4,3,2. . .
Old Jan 19, 2003 | 12:36 AM
MAXSRB's Avatar
Re: I'm gonna stick with ECTS, based on your reply.
I accept. My car idles at 3000RPM when i start up somtimes too. Happened twice also. As well, my car makes a grinding noise when I first start it in the morning. Its cold up here in Canada.
Old Jan 19, 2003 | 01:33 AM
happyricefob's Avatar
V^___^V
the highest for me @ idle was 1,200rpm, defintely clean our ur TB for better flow is the first step =)
Old Jan 19, 2003 | 01:42 AM
KWheelzSB's Avatar
Scroll UP &
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
