Walbro 255 lph Fuel Pump Problems
I installed one on a 1996 Maxima, and when I try to start the car and turn the ingition key all the way on the car does not even react everything just shuts off, it wont even crank !
can some one help me with my troubles?
Viktor
Viktor
![](https://maxima.org/forums/images/smilies/support.gif)
Nevermind noticed that you live in canada. Not much i can do down here in DC. All i can say is have a friend look at it and maybe they can see something you missed. Also write down all the steps you took to installing the pump. Maybe i can help you there.
I couldn't fix your brakes, so I made your horn louder
Originally posted by 96BLUMAX
Thats basically what i just did and no problems. Do you know if your battery is fine? You could have another problem that is not related to the pump.
Be aware that hitting the starter too hard with a hammer may damage a good starter on the new cars these days... if you have to, start with small "taps" as Tony suggested.
Try this first though... Have someone watch the headlights (or if you see the lights against a wall) as you try to start the car... If it dims alot (or goes out) your battery is low... I assumed you already tried either jumpstarting the car or recharging the battery?
Here's a stupid question... are you sure you are fully depressing the clutch pedal (manual tranny) or have the tranny in PARK (auto)?
MR2 T'd
07-09-2021 05:06 AM
