now im leaking coolant.... Please read!
Old Jan 19, 2003 | 07:17 PM
ny96max's Avatar
This morning after i moved my car on the driveway i noticed a small puddle of anit-freeze on my driveway. I later jacked my car up and crawled underneath to see where it was coming from. I saw the trail coming down a harness right next to the oil drain plug. Its a small drip i guess from what i could see.
Does anybody have an idea of where this leak could be coming from? Its the passanger side so im assuming the radiator is ruled out
im gonna go out to Max Performance this week and let Jeff take a look, but i was hopin maybe it was something i could fix myself.
thanks
Ant
Old Jan 19, 2003 | 07:24 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Re: now im leaking coolant.... Please read!
could be from the thermostat area..
Old Jan 19, 2003 | 07:37 PM
gtr_rider's Avatar
192.168.1.1
My leak is straight from the radiator
Old Jan 19, 2003 | 07:44 PM
ny96max's Avatar
Re: Re: now im leaking coolant.... Please read!
where exactly is the thermostat located?
anybody?
Ant
Old Jan 19, 2003 | 08:45 PM
96BLUMAX's Avatar
Check the connections to your engine and the coolant temp sensor. Also see if the resevoir is leaking.
Old Jan 19, 2003 | 09:24 PM
karguy's Avatar
Re: Re: Re: now im leaking coolant.... Please read!
anybody?
Ant
Front passenger side of engine you'll see radiator hose on water inlet near alternator.
Old Jan 20, 2003 | 02:10 AM
GoldenGlory
thanks
Ant
i had that exact same probolem 2 yrs ago ...
it was my water pump leaking ..
good luck !
Old Jan 20, 2003 | 02:43 AM
synix's Avatar
Have you worked on anything in that area? A couple days ago you changed the coolant temp sensor, right? Perhaps it has something to do with that...improper install maybe?
BTW, did you find anything out about the 'idle plunger' thing (cost, location and whatnot)? I'm having a similar problem with starting, except mine is much worse; happens in all weather conditions.
Old Jan 20, 2003 | 05:05 PM
ny96max's Avatar
its not my coolant temp sensor leaking, believe me that was the 1st thing i checked. My leak has been occuring long before i touched my ECTS. As far as the idle plunger, it costs $140 from Nissan. Ill probably change mine out next paycheck
i need money now to get this leak fixed and to have my UDP installed
Ant
Old Jan 20, 2003 | 05:06 PM
ny96max's Avatar
good luck !
and how much did that run you for a new water pump?
thanks,
Ant
Old Jan 20, 2003 | 05:19 PM
blakkrob's Avatar
I went to the dealer today for my leak. THey said id it was the waer pump it wouldn't run any more than $600 parts and labor.
Old Jan 20, 2003 | 05:53 PM
matty's Avatar
600$..thats alot of money...buy it and have a shop put it in...cost you about 80$ for the pump and prob 2 hours of labor or maybe alittle more...
Old Jan 20, 2003 | 07:03 PM
ny96max's Avatar
are you sure about $80 for the pump?? ive heard they cost around $300!!
Ant
Old Jan 20, 2003 | 07:21 PM
blakkrob's Avatar
I've heard in the range or $80- $120. THe labor is what hit's ya hard.
Old Jan 20, 2003 | 07:36 PM
ny96max's Avatar
The water pump i can get for "cost" not a Nissan one but aftermarket. And as far as labor id definitly have to see Jeff regarding the install.
Ant
Old Jan 20, 2003 | 07:58 PM
sebaxx's Avatar
thanks
Ant
Look like 2 months ago my car has the same....and the leak of coolant was exaclty under the thermostat....this radiator sucks, and with time, coold weather can brake easy and you will not notice wheres the leak...the problem of the oem radiator of maxima is that is just plastic made...and they dont have mode to fix it....i remplace the radiator for another one, new and made with aluminium more cheap, easy to fix and it cost me 112 dollars...and dont have problem since.
Old Jan 20, 2003 | 11:08 PM
GoldenGlory
thanks,
Ant
well my boys shop did the work
1 yr ago... cant member...he hooked it up..
i think it was like 75 or somethin for an aftermarket pump
then about if i can member round it off to 3 hours of larbor
less if ur 100% sure as too what ur doing
jeff should work it out to less then an hour maybe 1.5
he charged me about 400
but that was water pump replace/install
coolant fush and replace
larbor
oil change...and tranny service
took about almost 5-6 hours to get everything done
charged me 3 hours of larbor
water pump a bish to do
motor mount out jack up engine etc etc... a pain !!!!!!!!
good luck !
Old Jan 20, 2003 | 11:21 PM
synix's Avatar
Perhaps this has something to do with it? What type of coolant were all you guys with pump problems using?
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
followthadollar
Sep 17, 2015 06:31 PM
ag90fox
Sep 9, 2015 12:22 PM
