new clutch what the hell this is not normal!!! help !!! not happy with setup up
Old Jan 19, 2003 | 10:35 PM
RI-Max's Avatar
ok guys i put about 300 miles on my clutch (ACT Street clutch) and i still get this really bad bucking only in low RPMs. but if i rise the RPM at like 2,000 or higher it doesn't do it. is thier a special way to put the flywheel on??? so its balance or something casue its not getting any better. casue its only with i let the clutch grab (like off a red light) after that its fine HELP!!
Old Jan 19, 2003 | 10:42 PM
mtrai760's Avatar
'Trynna' is not a word
Hmm, it seems either people get clutch chatter with the ACT or they don't. I had clutch chatter for about 1500 miles before it finally went away. Upgrading your motor mounts or poly filling them will help alot! Good luck.
Old Jan 19, 2003 | 10:43 PM
plurco's Avatar
did you resurface your flywheel?
Old Jan 19, 2003 | 10:54 PM
RI-Max's Avatar
yup i resurface the flywheel. this is not chatter (think) it buck and u can see the wheel sake. what can it beee
Old Jan 19, 2003 | 10:58 PM
plurco's Avatar
you are scaring me now. I just ordered my ACT clutch. anyone else have ony trouble out of these?
Old Jan 20, 2003 | 12:27 AM
nadir_s's Avatar
vicodin ... gift of life
sit there and burn ure clutch for a long period of time... maybe that will help... ( i still think u need more miles for break-in because that's what my cousin told me when he upgraded the clutch).
Old Jan 20, 2003 | 12:33 AM
Toolrocks's Avatar
Mine did the same thing and eventually went away. What I found to help was tapping the gas slightly before I let the clutch out (in 1st). I would get the engine around 1800 and let off the gas and let the clutch out - the shudder wasn't as noticable. After 1000 miles and a trip to the track my clutch felt better than stock. Give it some time it takes some getting used to.
Old Jan 20, 2003 | 01:37 AM
Chunger's Avatar
My other car is a Hybrid
Take it easy on the clutch... at least for a little longer...
A lot of it has to getting accustomed to the new pedal effort. It's much harder to launch smoothly with a high performance clutch. Plus the stiff pedal seems to get better after a several hundred miles.
Old Jan 20, 2003 | 06:45 AM
RI-Max's Avatar
and i didn't clean the flywheel with brake clean . didn't change the pilot bearing too (casue didn't have the tool. i'll let it break in more tho i'll get back 2 u guys about it just please tell me its gonna go away tho.
Old Jan 20, 2003 | 07:24 AM
Sprint's Avatar
after 500 miles.. it gets less..
change your motor mounts and it totally goes away
Old Jan 20, 2003 | 09:47 AM
blizz20oma's Avatar
I'm so hood
After reading Sprint's summations from ACT clutch issues I think when I get a new clutch, no matter what it is, I'm going to take that as the time to replace my motor mounts - just because.
Old Jan 20, 2003 | 10:26 AM
luckee2bhere's Avatar
I just ordered my ACT too!
Whats this motor mounts thing?
Is it expensive?
Should I get it done when I get my clutch installed or give it some time?
Old Jan 20, 2003 | 10:29 AM
Sprint's Avatar
Is it expensive?
http://forums.maxima.org/showthread....tor+and+mounts
i got mine from sx7r... so you can ither buy a set from Cattman... Place Racing mounts... but they cause vibration at low idle.. or have a member do it.. or poly them yourself
Old Jan 20, 2003 | 10:43 AM
blizz20oma's Avatar
I'm so hood
After reading that thread and recalling a few others, I want to ask the mount guys if their oem mounts were torn or in bad shape at all. As in, if you replaced the mounts w/brand new OEMs, do you think the clutch chatter woulda been reduced as with the poly mounts?
Old Jan 20, 2003 | 11:26 AM
nadir_s's Avatar
damn nice write up sprint. I think I'm gonna just gonna wait till there's some pics to go w/ the instructions... i would love to attempt it myself but i can't think of anyone around here that could help me. Hopefully one of the helpful maxima DIY sites come up w/ it!
Old Jan 20, 2003 | 11:46 AM
RI-Max's Avatar
i did change the upper trans mount to a facorty one tho,but is the chattering noise going to go away????
Old Jan 20, 2003 | 02:11 PM
ThurzNite's Avatar
I just installed my ACT last week (also resurfaced fly). I also get this weird vibration w/low rpm engamements into 1st. After driving 500 miles, it's 1/2 gone. And just like you, if I raise RPM to 1200, I don't get that weird vibration. All stock mounts are 1/2 dead...I wanna poly them, but dunno what's a good poly to use.
Vibration doesn't bother me...I've experienced this in my 93 Maxima with OEM clutch.
BTW, I get into 1st gear w/o any gas. If I'm on a hill, I blip the gas, but never hold it as I let the clutch out. Haven't had any problems yet, keeps the car quiet and the acceleration smooth. However, I tried this technique in my bro's 2k Max w/stock clutch and it doesn't work. They have an issue with fuel cutout in low rpm, so it forces me to stall. Argh!
Jae
Old Feb 8, 2003 | 04:35 PM
It seems harder to shift the shifter into gear with my new clutch....what is that about?
TallTom
57
Oct 14, 2025 05:16 PM
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
RealityCheck
Oct 2, 2015 06:34 PM
Sep 27, 2015 08:37 AM
