help with intakes
Old Jan 21, 2003 | 03:55 PM
maxspeed96's Avatar
help with intakes
hey people...i have a 96 GXE and wanted to invest in an intake, but am not sure which kind to get. the regular cone that sits behind the battery seems easiest, but draws in hot air. and in the cold intake, you have to cut a hole in your fenderwell (which i dont think i want to do). Is there a cai out there available that i dont have to do any cutting to my car? And does anyone have either of these for sale? feedback will be greatly appreciated
Old Jan 21, 2003 | 04:07 PM
Jime's Avatar
Re: help with intakes
There is a group deal on the bomz right now for $65. Can't beat that, same design and the Place Racing Cold Air Intake. You can use it in hybrid mode which means no cutting or you can cut the hole and use it in cold air mode. I would suggest you get a decent filter for it though.
I cut the hole in my car and now I am going to sell it and it virtually impossible to see it because its almost under the battery and relay box so its not a problem.
There is not a cold air filter that does not require cutting. I know, I know, the Injen, but its still a warm air intake regardless of what anyone says.
Good Luck
Jim
http://forums.maxima.org/showthread....1&pagenumber=1
Old Jan 21, 2003 | 04:20 PM
JPMax's Avatar
What's next!?..
Your other option would be to get an Injen intake. www.Injen.com
The kit runs about $220-250.
No cutting required.
Old Jan 21, 2003 | 08:14 PM
ivelweyz
Your best option would probably be a home-made hybrid, $40. I'm making one and if you think you're up for it you should try it. Some links for reference...
http://www.drwebdesign.com/mymaxima/upperintake.html
http://www.vqpower.com/v2/modules.ph...howpage&pid=35
Old Jan 21, 2003 | 09:24 PM
happyricefob's Avatar
V^___^V
u can try a short ram + K&N filter + stock air ram, it's kinda half and half but it flows pretty descent... the stock intake arm sux cuz it's not smooth enough compare to short ram piping, also K&N flows better than any filter out there, lastly the stock air ram can input cold hair from outside give u a bit of extra boast...
Old Jan 21, 2003 | 09:34 PM
tbannon's Avatar
in my case i have JWT intake and a place racing mid pipe made by requin6. i believe he has the same setup as i do. Talk to him i bought the mid pipe for 40 off of him, he might still have some materials left. I love the setup nice and clean.
Old Jan 21, 2003 | 10:19 PM
sebaxx's Avatar
make by your own
Im agree with that...i made my own intake with the page above, and dudz ist the same...HP that frankencar, etc. and you can save more money to do other mod.
Old Jan 21, 2003 | 10:37 PM
tbannon's Avatar
i got a question how do you all suggest getting more cold air to my my hybrid. i was thinking about running some kind of pipe from the intake to the bottom of the car where the splash guards are. Cut a hole in the splash guard and make some some kind of scoop. I'll put some gutter guard over the scoop so i don't get any stuff up into the engine bay. what do you all think about that. do you think that will work
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
