Strut Problem - WTF?! ... pics
Old Jan 22, 2003 | 12:04 PM
emCee-ig's Avatar
I just ordered a cheapy strut bar under reccomendation from you guys saying there isnt any point in buying expensive ones from custommaxima.
so i got to ebay and get a 95-99 MAXIMA A32 FRONT STRUT BAR
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1876876729
I try putting it on and here is my problem
http://home.usit.net/~johntom/images/strut-w.jpg
see the part next to the welding, what is that on my strut !? its welded on so i cant take it off,
Its the same problem with both sides. How do i get past this problem?
http://home.usit.net/~johntom/images/strut-wo.jpg
Any help would be greatly appreciated.
Im a computer guy, not a car guy damnit =)
(sorry for links to pics, cant IMG it cause .org wont allow more than 50k )
Thx
Old Jan 22, 2003 | 12:26 PM
Sin's Avatar
Sin
Are you sure you aren't putting it on backwards? It appears you have the cross bar towards the front of the car as opposed to the fire wall. Try flipping it around and you shouldn't have that problem anymore.
Old Jan 22, 2003 | 12:55 PM
mzmtg's Avatar
Minister of Silly Walks
Just use a hacksaw to cut that little bracket off the car.
No big deal.
Old Jan 22, 2003 | 01:25 PM
tomj's Avatar
Ahhh, I see you have the dreaded "'99" problem. The '99 model year really should be considered the 4 1/2 Gen since it is so different. Just wait until you want to do other things ( y-pipe, etc.) Easiest solution is to go to the dealer and ask for an even swap with a '98. Just kidding. Sorry.
Old Jan 22, 2003 | 01:33 PM
1MAX2NV's Avatar
Cheap way...Take a dremel and remove that bracket.
Expensive way....Buy a Stillen.
You have a 1999.5 which already has some production changes implemented for the 2000 models.
Old Jan 22, 2003 | 01:41 PM
WizzaMax's Avatar
I have a 99 as well and you have to just grind the tab off just enough to fit...no big deal...I had the same knee-jerk response...but a freind with a grinder hooked me up and it is cool ...don't sweat it.
Old Jan 22, 2003 | 01:51 PM
emCee-ig's Avatar
Ok, thx for those telling me it was backwards, im a newbie, look my title says so, the org doesnt lie.
anyways, new problem , i have posted larger pictures with the problems
the right side of the bar is resting on the power steering fluid(????) tank ( i guess thats what that is, refer to intro statement, im a noob) and the middle lugnut does not line up , same problem on left side.
again, thx for all your help
here are the pics.
most are over 120k , the red circles indicate problem areas.
http://home.usit.net/~johntom/images/left-strut.jpg
http://home.usit.net/~johntom/images/right-strut.jpg
http://home.usit.net/~johntom/images/strut-fluid.jpg
http://home.usit.net/~johntom/images/strut-wtf1.jpg
and if my car is a gen "4.5" wtf do i do now?
and as a thx to all you gen4'ers, i will gladly do a logo or any other type of graphic you might need ( i cant afford to pay you =P
Joeycurl's Avatar
I bought a cheap one too from ebay and I didn't have the problem that you have...and yes! mine is a 99. Hmmm!!!
Maybe they wielded the flange on the wrong side of the middle hole.
Old Jan 22, 2003 | 02:09 PM
1MAX2NV's Avatar
NO...NO..NO....you had it right the first time. Now, it's backwards. Take a hacksaw or a dremel and chop the corner of that bracket off. Touch it up with some touch up paint. BTW, that's not the power steering fluid reservior. It's the brake fluid reservior. The power steering res. is on the passenger side.
here are the pics.
Old Jan 22, 2003 | 02:13 PM
1MAX2NV's Avatar
You can see from this picture. I totally removed that bracket.
http://photos.imageevent.com/1max2nv...e/DCP01124.JPG
The stillen strut tower brace comes with a cut out section to clear that part. I had a generic one before.
Old Jan 22, 2003 | 02:17 PM
1MAX2NV's Avatar
Another way...Easier than hack saw or dremel
Take a hammer to that bracket. Flatten it so the ring will clear. I would put a towel so you won't rub off any paint.
Old Jan 24, 2003 | 12:53 AM
ThurzNite's Avatar
OMG...I can't believe Sin suggested putting it in backwards. Heehee.
I agree, see if you can snip off the bracket where you're having issues. There's another cheapy fstb out there with the bracket already notched.
Good luck with the car. Let us know (with pictures!) how it all turns out.
Jae
Old Jan 24, 2003 | 02:18 AM
Max Noob's Avatar
1999.5 ???
Jae
will a 2k strut bar fit on his?? since the 1999.5 is gettin more based off the 2k model.. just a thought.. im prolly wrong though.
Old Jan 24, 2003 | 06:23 AM
sidewinder740's Avatar
Re: Strut Problem - WTF?! ... pics
Thx
I had the same problem. I just cut it off and applied touch-up paint and I was good to go.
Old Jan 24, 2003 | 07:08 AM
1MAX2NV's Avatar
Re: 1999.5 ???
No...2K FSTB will not fit 1999.5.
Old Jan 24, 2003 | 07:40 AM
96BLUMAX's Avatar
You dont even need to cut it. Just bend it back a little. Thats what i did on my dad's 5th gen that was giving me trouble.
Old Jan 24, 2003 | 08:18 AM
Nore474's Avatar
are you suppose to make it real tight across?
Old Jan 24, 2003 | 09:01 AM
WizzaMax's Avatar
the pictures look as though it is trying to be put on backward...ooops!
Old Jan 24, 2003 | 09:17 AM
dsupertech's Avatar
It appears the flange was welded upside down. Looking at those welds, they appear not to have been automated welds-- Human error. I could be wrong though.
Old Jan 24, 2003 | 12:35 PM
maximum810's Avatar
Courtesy Nissan makes a seperate FSTB just for that. Not all 99's have that bracket...mine doesn't at least.
Old Jan 24, 2003 | 12:58 PM
Sin's Avatar
Sin
Weird my 98' has it
Old Jan 24, 2003 | 07:55 PM
ThurzNite's Avatar
yeah, try to bring the strut towers together...but only do so hand tight. Any tighter and you'll have negative chamber (which isn't bad, but your car won't go straight as easily)
Jae
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
Johnny9595
Sep 3, 2015 05:18 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
