Do i need to bleed my brakes if i install new rotors and pads?
Old Jan 27, 2003 | 05:07 PM
silvermax2k2's Avatar
me and my friend got into an argument about this... and i was just wondering if some one could help me clear this up. thanks.
chris
Old Jan 27, 2003 | 05:10 PM
TonyGotSkilz's Avatar
Your supposed to, but you don't have to.
Old Jan 27, 2003 | 05:27 PM
ladeesman's Avatar
It's always a good idea....that and get you some new brake fluid.
Old Jan 27, 2003 | 05:53 PM
karguy's Avatar
You can probably get away with not bleeding them but why not bleed them. I flushed my brake system every time I change pads which is about every 50K. It is just four small tire footprints and brake system between you and a telephone pole. Some things you gotta do right.
Old Jan 27, 2003 | 05:59 PM
yea, i already did that once! (not with my maxima)
Damn! i hate being wrong! i supose i will bleed my brakes... in the freezing cold thanks guys.
-MaxPayne-'s Avatar
Don't you only need to bleed the brakes if u change calipers or brake cylinders?
Old Jan 28, 2003 | 12:00 AM
KWheelzSB's Avatar
Technically speaking. . .
You are not required to bleed the brakes during a pad/rotor change.
Unless you're removing calipers, upgrading to stainless-steel braided lines, or performing another service which could allow air into any part of the hydraulic brake system when doing your service, the brake fluid can be regarded as having it's own separate maintenance schedule from brake pads/rotors.
Most people (myself included) just end up doing a bleed with the pad/rotor change because we're already down there, and it's convenient.
But again, technically, NO. These two services do not need to coincide. When you get a shop-quote for the work you outlined in your thread, most do not automatically include a brake-fluid flush.
Brake fluid should generally be changed once a year for passenger vehicles, more often for racing or high-mileage applications. Brake fluid is hydroscopic, (absorbs H2O) so it's performance deteriorates over time and H2O in the system can cause all sorts of problems if left unchecked.
If it's been over a year since you did it, bite the bullet & take care of 'bidniz. Pick your warmest forecast day.
For easy bleeding, check out www.speedbleeder.com I have these & swear by them. Brake-bleeding is a walk in the park one-man-job with these things.
Old Jan 28, 2003 | 12:10 AM
UTIMaxima's Avatar
You don't need to unless you remove a brake line, or otherwise cause air to possibly get in there. But you might as well, only takes a few minutes.
Old Jan 28, 2003 | 10:40 AM
jbreit's Avatar
I agree...you don't neeeeed to...i have cheated lots of times and just slapped in new pads...mostly on my beater cars. if you so much as crack the bleeder screw or a line open though, you should bleed them.
too often the brake system is neglected this way. I think most owners manuals would tell you that you should replace the fluid in your braking system every two years...because over time brake fluid and aluminum with generate "grit".
MaxLife17
Sep 8, 2015 02:36 PM
homeyclaus
Sep 3, 2015 06:15 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
