Transmission Fluid
Old Jan 28, 2003 | 09:55 AM
dmirocha's Avatar
Transmission Fluid
Are there alternatives to Genuine Nissan Automatic Transmission Fluid? What are they?
Old Jan 28, 2003 | 10:00 AM
Grey00lustre's Avatar
Do a search this topic has been discuss before....redline ATF, mobile 1, amsoil...
Old Jan 28, 2003 | 10:29 AM
njmaxseltd's Avatar
Any "ATF" rated transmission fluid will work.
Old Jan 28, 2003 | 11:30 AM
iwannabmw's Avatar
True, but using something like Type F could prove interesting....
Old Jan 28, 2003 | 02:32 PM
WizzaMax's Avatar
Dexron III, Mercon rating as recommended
not +4 or weird stuff ...
Old Jan 28, 2003 | 02:53 PM
taeMAX97's Avatar
i have a question... is it neccessary to get transmission service done? i have 97 SE with automatic and about 110,000 miles on it.
i called the local nissan dealer they qouted me $79 for basic( i think they said drain and flush..) and $129 for T-Tech(where they hook up a machine or something) which one is worth it?
Tae
Old Jan 28, 2003 | 03:01 PM
99Maxima5sp's Avatar
Tae
Yes, from what ive heard, its much better to get it done by that new machine that sucks all the fluid out. I would anyways.
While were on the topic of trannys, do any of you 5-SP guys get a metal on metal sound in the beginning of first and reverse when you are JUST letting go of the clutch. I get it SOMETIMES, usually only when its cold. Sounds like bad brakes for example. Friend said it sounded like i needed some tranny fluid, but wasnt sure.
Eric
Old Jan 28, 2003 | 03:18 PM
iwannabmw's Avatar
Eric
I've never experienced that, but it could be as simple as your clutch pedal. If you're in neutral and press the clutch in and out do you hear it?
taeMAX97: If the tranny hasn't been serviced in while, the full flush is recommended. If you've been changing fluid regularly, the drain and fill should be okay.
Old Jan 28, 2003 | 03:35 PM
Nope. Its definately from outside the car..
Eric
Old Jan 28, 2003 | 07:10 PM
iwannabmw's Avatar
Eric
How old's the clutch. It could be the grease that's on the release lever or the rod from the slave cylinder that pushes on that lever has dried up.
Need help
23
Oct 2, 2015 08:56 AM
Pied
Sep 26, 2015 03:29 PM
