Installed Energy Suspension FSB & Endlink Bushings...Thoughts and Pics
Old Jan 28, 2003 | 12:37 PM
Requin6's Avatar
Well after doing a lot of work to other members Maximas it was time to start off the week of working on my own. I installed the ES FSB frame mount and endlink bushings, part #'s 7-5118G and 9-8106G respectively. This was a good start to the week of modifications. This weekend i plan on putting on the VI to go along with the JWT ECU i have been running in my car for the past week. The car pulls like crazy with the ECU i cant imagine what it will be like with the VI. and i will be dynoing with the JWT ECU and VI this sunday, so i am excited for that. anywho, that is for another thread later.
As for the bushings, the install was not bad. Took about 1.5 hours from the time i started jacking up the car to the time i took it off the stands. A few tips for someone who may be putting these in in the future. Take BOTH (left & right) frame mount brackets off first before taking off the endlink. there is not enough play in the endlink to do each side at one time. I got tired of using force in such a small area so i pulled out the air tools. the frame mount bolts were pretty well on there. i am sure they will come off with a normal ratchet but since i have air tools at my disposal i just went the easy way.
As for the ride, as soon as i pulled it out of my driveway and hit the lip that meets the road i noticed a more solid feel to the front of the car. Going down the steering is a little more sound and solid. the little jitters in the wheel have been reduced. taking turns feels solid. if i had to describe the feeling in a few words they would be....Solid feel, more control, front end secure and more smoothness.
i took some pics of the install, they can be found here...
http://www.cardomain.com/member_page...=214548&page=4
this is a great little mod for those picky types like myself who just wants their car to be the best it can be. i payed $21 shipped for everything and have 4 extra endlink bushings to boot. The bushings were $7 for the frame mount and $7 for the endlink and $7 for shipping across the country. but i am very pleased with the result.
--Paul
Old Jan 28, 2003 | 12:51 PM
96BLUMAX's Avatar
Cool, didnt realize that they were that cheap. That is now on my list once i fix this tranny problem. Check out my 5speed trouble thread and see if you have any ideas.
Thanks,
Justin
Old Jan 28, 2003 | 02:07 PM
MAXIMARK's Avatar
Energy Suspension - GOATROPE!!!
So I read your post and think, cool, I will call the parts store and get a set for my MAX - wrong! I tried AutoZone and Advance/Discount Auto Parts - neither one could get (or even order the parts). I'm at your mercy - who'd you order them from??? Be Safe, Mark V.
Old Jan 28, 2003 | 03:05 PM
Requin6's Avatar
Re: Energy Suspension - GOATROPE!!!
http://www.suspension.com/s.b.bushings.htm
i called instead of using their order form.
Old Jan 28, 2003 | 04:40 PM
bhmax's Avatar
Some people have reported more NVH (noise, vibration, harshness) with these. How much would you say that has changed on roads that are less than ideal?
Old Jan 28, 2003 | 04:46 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I installed my FSB and endlink bushings and there is less NVH at all conditions. People who are experiencing problems probably installed them incorrectly (not enough lube, not tightening suspension bolts with suspension at static ride height or simulated static ride height, FSB facing the wrong way, etc).
Old Jan 28, 2003 | 05:02 PM
Requin6's Avatar
i experience less NVH. its a lot smoother and controlled.
Old Jan 28, 2003 | 05:43 PM
BEJAY1's Avatar
Conecarver
No increased vibration here either. Car might push/understeer just a touch more but hardly noticable. Just installed the ES control arm bushings but no telling harshness on those quite yet. Poly steering rack bushings up next...
Old Jan 28, 2003 | 06:07 PM
TurDz's Avatar
To anyone interested....please don't change the Control Arm bushings. They make the ride really harsh and the steering wheel vibrates a lot more.
Old Jan 28, 2003 | 10:09 PM
xHypex's Avatar
I don't know what suspension mods you all have, but after installing my bushings (FSB and endlink) I could noticeably feel imperfections in the road more than before the bushings.
-hype
Old Jan 28, 2003 | 10:40 PM
96BLUMAX's Avatar
But that is a more sporty feel.
Old Jan 28, 2003 | 10:46 PM
xHypex's Avatar
I never said I don't like it Feeling the road more can be described as an increase of NVH though.
-hype
Old Jan 29, 2003 | 03:37 AM
TurDz's Avatar
-hype
curious...what is NVH?
something vibration right? hehe
and also, I'm with hype...I got a lot more road feel, which is good for some surfaces but horrible on others (small potholes, uneven roads, speed bumps).
Old Jan 29, 2003 | 07:32 AM
JustMaxin96's Avatar
Re: Installed Energy Suspension FSB & Endlink Bushings...Thoughts and Pics
Damn Paul I thought you were not going to do a VI? So you really like the JWT ECU? Does it give good low end gains? This is next for me.
Also glad to see you like the brushings.. I may do this if someone is kind enough to let me come over and use their tools.... and heater.
Old Jan 29, 2003 | 08:39 AM
xHypex's Avatar
NVH = Noise, Vibration, Harshness (at least that's what I've always know it as). The bushings help round out a suspension setup, but I think the more suspension mods you have the more you'll notice the results.
-hype
Old Jan 29, 2003 | 09:16 AM
Requin6's Avatar
-hype
lets see i have FSTB, B+G springs, KYB AGX struts, on 17 inch wheels. the bushings really make the front end feel like its more secure and well put together. just my .02
Old Jan 30, 2003 | 01:26 PM
MAXIMARK's Avatar
...don't change control arm bushings?
has anyone else done the control arm bushings and had unsatisfactory results like TurDz? I was able to purchase the Energy Suspension bushings from www.suspension.com I was very satisfied with pricing and customer service. Anyone have any suggested tips for changing out the front end links and sway bar frame bushings?
Be Safe, Mark V.
Old Feb 1, 2003 | 09:11 PM
costcowholesale's Avatar
I got a question, what kind of tools do I need? all I need is 14mm ratchet set to install them?
Old Feb 1, 2003 | 11:38 PM
Requin6's Avatar
yes i believe so...some extensions will come in handy.
Old Feb 2, 2003 | 05:42 AM
Crooklyn's Avatar
check out http://www.courtesyparts.com/ they sell the energy suspension kit for the Max...
Old Feb 2, 2003 | 09:39 AM
TurDz's Avatar
one word...ripoff.
Old Feb 3, 2003 | 12:13 PM
bigmaxhi's Avatar
I couldn't find part# 9-8106 on the website. It said NA under the endlink column. It only had part numbers for the control arm and fsb bushings.
Old Feb 3, 2003 | 03:14 PM
MAXIMARK's Avatar
www.supension.com
try calling suspension.com (I believe I spoke with Bruce) he can help you with parts numbers and selection. Be Safe, Mark V.
bigmaxhi wrote <I couldn't find part# 9-8106 on the website. It said NA under the endlink column. It only had part numbers for the control arm and fsb bushings.>
Matt93SE
May 24, 2019 02:58 PM
Quickgtp
Apr 13, 2017 03:30 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Team STILLEN
Aug 10, 2015 04:29 PM
