air intake - pop charger
Hey all. I am probably going to get an air intake this afternoon from the local performance shop. just the pop charge. I am not sure what brands they have but they tell me they have them between 40-70.00
Here are my questions...
Is 3" the correct opening?
Is it easy to remove my current stock air filter chamber
what tools will i need
ANything to be warey of?
Thanks In Advance.. you guys are great!
Dan
Dan
Originally posted by NmexMAX
Get under your hood and see for yourself, that's what most of us did
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Just looking for some friendly advice. the only thing I have ever done to my car is put a drop in air filter and changed spark plugs on my old saturn..
Originally posted by JsL
What a rip off. Thats like buying a geo metro for $25,000. Go on ebay and bid on one. I know ebay doesn't sell the highest quality stuff, but the price reflects it. They have a CAI on there for like 60 shipped or so...get that.
You do not need a MAF adapter. If you look inside your airbx top, you'll see a gold colored piece, remove this, attach the filter to it and bolt it to the MAF. You may need to use a little silicone to seal the plate to the MAF.
I used a $20 AutoZone filter & some K&N oil I already had to make this:
![](http://images.cardomain.com/installs/135000-135999/135097_183_full.jpg)
![](http://images.cardomain.com/installs/135000-135999/135097_194_full.jpg)
by looking at your pictures i cannot tell, but i know you removed the top section of the air filter box, did you remove the bottom part as well?
did the the cone style filter you got from auto zone come with all hardware needed? like seals or anything? i think i am talking out of my @ss. lol
You can take off the entire intake setup before the filter. There's no air running through it, so you might as well take off the 4 miles of tubing. The lower part of the filter box only has something like 3 or 4 bolts on it.
Honestly, get your intake stuff. No special tools are needed, just a screwdriver and a socket set. When you get your stuff, just open your hood, take off the filter box, unbolt the MAF. Everything should be 10mm bolts or large hose clamps. It's probably the easiest mod you can do to your car other than clear corners. If you know what you're doing, you can install the thing in less than 30mins. If you want to take your time, maybe an hour.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
i also just called budgetexhaust.com and they told me for a y-pipe 160.00 shipped. i am going to order it probably later this week once i get my income tax check back. when i go to buy the cone filter, anything i should look for? cause they got several kinds.
Dan
I offerred a while back to sell my popcharger style intake...
it has the adapter already for install...let me know if you are interested...pics on the engine page of my website
The website does not work, anyway. .I bought one @ autozone this afternoon. got it installed. . had a little problem with the adapter coming off the stock box, but i got it. i turned on the car, and hit the gas a bit.. i can hear the difference. not much, but i can hear it..
yawn.. i am getting out of work in like 6 minutes.. thanks for the help guys!
KabirUTA13
19
10-17-2015 02:15 AM
zzznightmarezz
09-21-2015 06:32 PM
Keyno McMike
09-21-2015 07:18 AM
pears
09-18-2015 05:25 AM
