power lock problem in the cold
Old Jan 31, 2003 | 10:06 PM
96_Infiniti_I30's Avatar
my back door on the driver side doesn't want to open when its cold out,not even manually it wont unlock.When it warms up alittle outside it works fine.What can i do so that it doesn't do this again.Is their a solution to this problem? any info would be greatly appreciated.
Old Dec 19, 2003 | 10:52 AM
dul311's Avatar
Did you ever get an resolution to this problem? I have the same exact issue with my 99 Max SE. That specific door also makes a weird little chirp when I lock or unlock it.
Old Dec 19, 2003 | 10:56 AM
soulrupture's Avatar
This must be fate. This morning my rear door on the driver's side did the same thing. It would not work till it got warm in the car. It is the first time this has happened and I just thought it was the cold. Interesting
Old Dec 19, 2003 | 10:59 AM
PoePoe2797's Avatar
water got on the lock.....spray some WD-40 on it and it should be fine. Of course youll prolly have to take off the door panel...
Old Dec 19, 2003 | 11:23 AM
Entropy's Avatar
I would get some good lithium grease and get a little on the latch and locking mechanism in the side of the door. WD40 or similar will work, but I think liquid solutions are usually a more temporary solution. Once the grease works in a bit, it should be good for quite some time.
Edit: As clarification... I meant to take the panel off and move the lock - put grease on any contact points, the latch, and the mechanism on the side of the door.
I saw the same problem on a 91 DSM and as far as I know it has worked ever since (for a couple years now anyway).
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
Hailstatejig
Sep 2, 2015 06:52 AM
