transmission problem
Old Jan 7, 2001 | 12:48 PM
max1ma97se's Avatar
ok here the problem i have 4.5 quartzof redline atf the 1st week waswonderful but now 2nd to 3rd shift goes up 1.5k i neutral then shifts wtf! and in 4th gear i barley push the pedal car goes from 1.5k to 4k rpm in neutral before the car even goes faster its not downshifting it being gay. should i get a shift kit i dont want a valve body? should i put my car in the shop?
Old Jan 7, 2001 | 01:56 PM
sinewave's Avatar
I don't know much about Redline ATF, but I've been running Royal Purple ATF in mine for a year now without any problems. You may want to contact Redline to see if they have logged any problems with that type of ATF.
Were you having shifting problems before? I may be that the bands in the tranny are shot.
Old Jan 7, 2001 | 02:13 PM
Eric L.'s Avatar
Were you using Redline ATF, or Redline D4 ATF? You should be using Redline D4 ATF. I think normal Redline ATF is Dextron IIE equivalent, which should work with Nissans, but the recommended manufacturers fluid is Dextron III, which Redline D4 conforms to.
Old Jan 7, 2001 | 04:40 PM
max1ma97se's Avatar
redline atf
that all the bottle said. also where can i get a shift kit for my car how much and how do i install it?
Old Jan 7, 2001 | 05:19 PM
Eric L.'s Avatar
Re: redline atf
I think you are using the wrong ATF then. Well, not really wrong, but it's not the recommended grade of ATF by Nissan. I'm not sure what the difference between Dextron IIE and Dextron III is, but you might want to try a drain and refill with normal ATF and see if your problem goes away before you spend the bucks on the shift kit.
Old Jan 7, 2001 | 05:27 PM
max1ma97se's Avatar
alright
where can i order redline d4 atf?
Old Jan 7, 2001 | 09:48 PM
dch95's Avatar
Re: Re: redline atf
[QUOTE]Originally posted by Eric L.
[I][QUOTE]Originally posted by max1ma97se
[I]that all the bottle said. also where can i get a shift kit for my car how much and how do i install it? (
Quote
If you want a shift kit for your car and believe that it will "fix" your problem then I think that,s a turn in the wrong direction. A shift kits main job is to make the tranny shift into each gear harder and quicker than what it used to do. If there are seals in the tranny that were damaged from the different fluid then the kit won,t make any difference. The seals are either FUBAR or changing the fluid may help fix your problem. Hope this helps.
[Edited by dch95 on 01-07-2001 at 11:51 PM]
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
