the car shut down on the morning
Old Feb 1, 2003 | 05:03 PM
sebaxx's Avatar
well i dont know what happen this time. My maxima auto, shut down. When i start the car on the morning, and shift from P to R, 1, 2, gear the rmps goes down and the engine stop. I have to drive very slow on D to avoid this problem, after 1 mile of something like that if i put 1,2, the car goes ok.
the car shut dows like a 5speed, if you shift from N to 3,4, 5 gear with the car stop and you put the brake, then loosen the clutch is normal that the car shut down cause you dont let the car move and dont press the accelerator. My car feels like that.
any suggestion? i will go the dealer to check the valve body, any suggestion?
Old Feb 1, 2003 | 06:57 PM
kratz74's Avatar
check your computer code. if nothing, then maybe start basic and pull and check the plugs,etc... Could be computer related though since the engine has a different program for when its cold than when its hot. Tons of possibilities are running through my mind now-better check tha computer code in the FAQ part of the site.
Old Feb 1, 2003 | 07:51 PM
sebaxx's Avatar
i check the ecu codes, and tranny codes, but didnt show me anything...i dont know if is a mechanica problem with the tranny.
Old Feb 1, 2003 | 08:13 PM
kratz74's Avatar
Odd. Hmmm it just souds like there is a problem in the cold start mode. Maybe the thermostat? Something is making the car run poorly only in this mode. I think Im on the right track but I'm no mechanic.
Old Feb 1, 2003 | 10:21 PM
sebaxx's Avatar
yes all this happen just in cold start(like 8 hours later) after my car warm up, the tranny doesnt fail after next day.
Old Feb 2, 2003 | 12:03 AM
maxspeed233's Avatar
i have the same f...g, problem.
Old Feb 2, 2003 | 01:50 PM
sebaxx's Avatar
hi, look i tried to do this....first start the engine..shift from P to 1 gear, then 2, then d, then go to P, but for a few times, and i dont let the car move with brake peda...i just shift the gears... after that the problem didnt come again..
do you thing theres a solenoid that doesnt work after i move a few times the gears???
Old Feb 2, 2003 | 01:58 PM
sebaxx's Avatar
some one told me that maybe is the shift solenoid, it can slipping after some time.?
Old Feb 2, 2003 | 04:01 PM
FLO_BOY's Avatar
read my post on this page...
...called "symptoms of bad torque convertor"...sounds like the same
issue...have your TC checked out...
my $0.02,
FLO_BOY
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
erniel
Aug 8, 2015 09:32 AM
