In Need of Desparate Help after KS
Old Feb 1, 2003 | 05:50 PM
DerekJ212's Avatar
When I bought my car, I checked the codes and saw an 03 04 and so I bought a knock sensor. I replaced it about an hour ago and all went pretty well. It was incredibly tight on to begin with and took a full two hands pressure to get off. I used a telescoping magnet for the whole process if that matters. Once we fiddled a lot with the harness it went in and we replaced the U clip. I then reset the ECU, started the car, revved to about 5-6,000 and then turned it off and checked codes to find 05 05 --NOTHING! Then I was backing out of the garage and at around 2,000RPM the CEL came on. It was never on before, it just had a code in the ECU. So I immediately turn it off and check for codes....still 05 05...I was low on gas, so I drove to the gas station around 40MPH with the CEL flashing. It says that has something to do with a misfire...I checked codes again and still 05 05. I am really upset, I dont have any money to bring it to a dealer. Ive looked over everything and I dont see any loose connections or anything. The sensor is snug, but not TIGHT as before, it is a good one hand of pressure. What do I do??? Please help!
Old Feb 1, 2003 | 05:55 PM
DerekJ212's Avatar
By the way, I now have full gas and checked the grounds. Im sitting here waiting for an answer so please help.
Derek
Old Feb 1, 2003 | 07:44 PM
njmaxseltd's Avatar
Check the plugs on all your coil packs and injectors.
You upset something while you were working on the KS.
killer00
May 13, 2010 07:52 AM
'02_EMILBUS
Feb 19, 2008 08:59 AM
'02_EMILBUS
Nov 10, 2007 03:33 AM
LILMAN
19
Dec 22, 2006 05:30 AM
thefed
52
Jul 12, 2006 12:31 AM
